Originally Posted by TheRealSy90
Did the ISIS fpr work well? Haven't known anyone that's used it.
It works fine, it just doesn't hold fuel pressure after the fuel pump primes. Adjusts fuel pressure perfectly and gauge reads clearly. But according to this guy on ka-t.org:
Originally Posted by i_slide
I'm pretty sure every aftermarket FPR does not hold pressure after the pump is finished priming. (At least all my aftermarket FPR's did not such as: no names, ISIS, Tomei, etc.) Don't sweat it, its normal. Just start the car up during the second priming cycle and see if that helps. It should not cause a hard start issue.
