sr20 starts runs then wont start
Like it says when i drive the car it starts and runs fine but when i park and shut it off it wont start without being pushed. The car is running super rich I'm just waiting on a tune don't know if that would have anything to do with why it wont start back up but i thought it was worth mentioning.
![]() Join Date: Nov 2010
Why does it need a tune? Have you done upgrades or modifications that alter the fuel delivery?
Does the starter work when boosted? Investigate your alternator fuse, your wiring between the alternator and starter, and possibly your alternator although I hope youve thought of that already!
The battery is fine all the connections are there the started keeps trying to turn it over but it just won't fire. Also to answer the other question it's got 550cc injectors a 255lph pump and a nismo fpr the reason I think it needs tuned is when I bought it had an enthalpy tune which blows smoke under throttle.
#6 | |
My next guess would be a bad relay or circuit. Probably with your injectors if the problem started after upgrading the fuel system. The engine needs spark and fuel in order to turn over when cranked and is more than likely not recieving one. Id check the ECCS and fuel relays. Pull the fuel feed line off and see if fuel comes out when cranked, easy to access and easy to diagnose. Your injectors may not be firing properly in order to start the vehicle though even if the rail is getting pressure. |
See the thing of it is I can go out and start it up right now and i can drive it around no problem but as soon as I park and shut it off that's when it won't start back up so I feel like the injectors and fuel pump are fine cause they both work under full throttle just when I go to start it back up there's nothing |
#8 | |
![]() Join Date: Feb 2014
I would warm it up and check the spark when it won't start to verify ignition pulse. Rent a fuel pressure tester also it should read 43 psi with vac line unplugged.
Sent from my SAMSUNG-SM-G920A using Tapatalk |
#17 |
Also I always run copper plugs as there is better performance but don't last as long. Bkr7e plugs gapped to about 28-30 depending on boost level. I would not think that is your issue
+1 to this. Those Crank angle sensors can be really bitchy when they start to go. I also reccomend Ngk BRK7E V power plugs, gapped to 0.28", ran way better than my Iridium plugs. Although I dont have any reason to believe the plugs would be a big issue as they sound like they run fine usually.
#20 |
#23 |
![]() Join Date: Sep 2011
Trader Rating: (18)
There's a screw on the back of the ecu turn it and the red light inside will flash the code you'll have to count it and it pauses between the flashes so you can get a code
#24 |
#26 |
#28 | |
#29 |
My bet is on something wrong with your wiring. The vehicle should fire if the starter is spinning the flywheel. Perhaps it somehow isnt making contact? idk. Either way if it will push start but not turn over with the starter... thats an issue that I would be worried about...
