![]() Join Date: Feb 2002
Enjuku Racing - ISR Performance Tubular 4-2-1 Header - Nissan 240sx KA24DE 91-98
ISR Performance Tubular 4-2-1 Header - Nissan 240sx KA24DE 91-98 ![]() ISR Performance 4-2-1 Tubular Heads for the Nissan 240sx KA24DE 91-98 year models. Expanded to 3" Flange to enable easy bolt-on application to stock cat or any aftermarket test pipe and exhaust system. Solid stainless steel construction for long-lived durability. Professional, precise welds for smoother flow and no leaks. ** All ISR Performance Products are Designed for Off Road Use Only ** Tubular Headers If you don’t have enough flow through your exhaust, back-pressure can build up, robbing your engine of power and eventually choking the life out of it. A set of ISR Performance 4-2-1 tubular heads helps your KA24DE breather easier by providing the high-flow exhaust system you need to keep pressure in check. These pipes are beautiful, durable, and work great on the track. Give your car a race-engineered exhaust to run with. Race-Quality ISR Performance tubular heads are premium performance upgrades over your stock exhaust setup. Make sure you understand how to use this component in accordance with local emissions laws before installation. We’re proud to bring you the best aftermarket import parts from coast to coast. Call our trained technicians at 888-SR20DET if you have any questions, concerns, or want to talk shop. They’ll make sure you get the parts you need for the ride you want. Order your tubular heads today from Enjuku Racing. In Stock and Ready to Ship! 219.95
