Old 03-26-2014, 08:26 PM   #1
SnaggleToof
SnaggleToof is an unknown quantity at this point
s13 cluster subharness diagram?
I am looking for a wiring diagram for the s13 needle cluster subharness.
I cut my cluster subharness in half to wire it to a NX cluster harness, not realizing that there were two yellow/green wires, two black wires, and two red/black wires.
The cluster subharness has three pins on one side (that go into back of cluster) and 2 pins on the other (to chassis harness)
I can find diagrams for the three pins on the back of the cluster, but nothing for the other end. Any help anyone?
Here is the harness I'm looking for. (But needle cluster, not the HUD cluster)
SnaggleToof is offline   Reply With Quote
Old 03-26-2014, 09:48 PM   #2
zerodameaon
zerodameaon's Avatar
The harness on your regular analog cluster is the dash harness in the car, the subharness in the picture plugs into dash harness to allow the use of the HUD. Look for a diagram of the dash harness or better yet search for the writeup on the NX cluster. They are out there, a friend recently did it and used a write up he found. Or look in the FSM that will tell you as well.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
