![]() Join Date: May 2011
RH Door / Molding Water Leak
I am having an issue with my S14 leaking during heavy rains. I have replaced the door weatherstrip that runs along the top of the door opening but it is still leaking. I suspect it is somewhere behind the molding that runs along the top of the door/roof line. Is there a known leak point that I can immediately look into? I plan to do some water leak testing this weekend with a hose otherwise.
http://www.youtube.com/canaanmanley |
Does your door align with the frame properly? Even the slightest offset can cause leaking to occur.
yes, it does. That is why I am stumped.
