Old 09-10-2009, 08:43 PM   #1
nate_drake
nate_drake's Avatar
nate_drake is an unknown quantity at this point
here we go.. problems galore.
so here heres what i have done, i did the headgasket on my car and have it started again. it was running ok after starting it up again after hg then it started misfiring bad, and running really really rich. black smoke out the tailpipe rich. i have stock inj in at the moment with a new gt2871r. so if anything i thoiught it would run lean.... could air pockets in the cooling system cause this? my spark pluugs are black and are dry though when i take them out. i checked the gaping. compression shows 140 - 145 on all 4 cyl.
and also the car wouldnt start with my new power fc, it would start when i had the map sensor pluged in but still misfire..4
any ideas would help out alot.....
thanks for your time.
nate_drake is offline   Reply With Quote
Old 09-10-2009, 08:46 PM   #2
nate_drake
nate_drake's Avatar
whoops should also add this is for an sr20 s13 blacktop.
Old 09-10-2009, 09:52 PM   #3
Sileighty_85
Sileighty_85's Avatar
Vacuum/boost leaks
check all hoses and vacuum lines
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
