#31 |
![]() Join Date: Feb 2009
I remember seeing those pics a while back. I'm glad you're recovering from this and doing what you planned albeit in a bit of a different fashion.
Any idea what the engine should be putting down?
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
#32 |
SR with a VE head is a whole different ball game.
#33 |
#35 |
![]() Join Date: Aug 2009
Trader Rating: (28)
![]() Feedback Score: 28 reviews
I remember your old thread as well. Glad to see you've got back on track.. and this build is amazing! Love everything you're doing with it.. Definitely in for updates!
#36 | |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
exactly! you can get a ton of power out of this type of setup
https://instagram.com/eck_matthew/ |
#37 |
Hello, why are you gonna use a VG trans ,instead of the VQ there is a forum member here that makes adaptor plates.
Reason I ask ,is because Im in the process of gathering parts for an SR350 also. From my research if you stick with the VQ trans,now you dont need to make a tranny mount & you get to keep the carbon driveshaft.Plus shifter placement stays like OEM. Z33 trans is about the same price,if not less. LMK,either way mad props on the build
MR JACKSON. |
#38 | |
Trader Rating: (18)
#40 |
why so much power? lol, that is a shit-load!!!
* S14SR22 * 9.0 c/r * GT3071R * |
#43 |
Trader Rating: (18)
For the class im in, its not horrible. The MAIN thing is to not have more power then the car/driver can handle and to also not have to much lag on acceleration. The turbo choice is perfect and everything that has been picked for the car has been carefully thought out to make sure that we don't sacrifice any of the acceleration or handleing. The world racing TC has even more then what im going for. Also, there are actually alot of 4-cylinder cars running 600+hp in modified and unlimited class. Like I said, as long as the car/driver can handle the power and the acceleration is on point...the 700-800hp will work out just fine. Look at all the other forms of road racing and the insane power that some of them put down...its all about the car and driver being able to handle that power.
#45 |
Trader Rating: (18)
Yes. I have been doing some time attack events for awhile in my previous cars (WRX, S13, and S14) but this is a bit of a step up in many ways but i will be taking it easy on the tracks for awhile to get used to the new chassis/power/setup and to also work out any little issues in the car/tune
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 11-24-2011 at 06:05 PM.. |
#46 |
Trader Rating: (18)
CAR STRIPPED DOWN UPDATE...PART 1!
differential taken out to have the tomei differential put in and the SPL bushings put in. subframe dropped out only after removing all the brackets that were in one way or another over lapping eachother...here are just some of the brackets the subframe subframe stripped down gas tank dropped...still had about 3/4 of a tank. all of the fuel/brake lines from the car every last wire from the car (getting a custom harness from Touge Factory) the tubbing in the engine bay and the speaker/storage area in the car still has to come out...200+ spot welds! ZERO RUST ON THE WHOLE CHASSIS ![]() hopefuly the spot welds and everything are done by the end of this weekend so it can head out for cage. for awhile.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 12-07-2014 at 12:29 PM.. |
#51 | |
Trader Rating: (18)
how much for the radiator support?
#52 |
Trader Rating: (18)
Not a HUGE problem, just a bit of a speed bump. Went to set the motor in the engine bay to see if everything cleared...it didn't hah. Intake manifold is WAY to big for a Z engine bay. We are going to have to make one that will fit. I already drew up some designs to go off of, still kind of mad though but with this engine not going in an S-chassis...i kind of expected some things to not fit right and need to be one off peices. We are going to stay with runners that are the same length, but basically come up with a whole new plenum style. Stay tuned for that!
the line on the intake manifold, would give me about 1/4" clearence between the engine and strut tower wall. Also, all the Aero was ordered today (black friday) along with a wilwood pedal board. The aero won't be in till probably January.
https://instagram.com/eck_matthew/ Last edited by Imarvin240; 11-19-2014 at 03:18 AM.. |
#53 |
That sucks about the Plenum... I have the Mazworx's proto type plenum(first VVL setup they made, was in a blue S13 hatch) going in my S14. It's about twice the size of yours... Looks like it will be a sick build, good luck man.
My SR20VET |
#54 |
![]() Join Date: Nov 2011
Definitely a bad experience on that event!
But glad to see your turned the negative into a positive! Great to see a build coming along!
Intangible Visionary: Multimedia Production |
#55 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Looks interesting keep up the build
My Build: The "Coupe De Ville" 1JZ Build!! |
#56 |
![]() Join Date: Jun 2008
Going by what you've drawn even the RHD version won't clear the tower. I'm sure you already have a plan, but most likely it going to involve stock runners with custom plenum right?
#57 |
![]() Join Date: Oct 2006
stock vvl runners are straight and point up a lil... they're not gonna help him. They're gonna have to make something dope from scratch
![]() HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#60 |
Trader Rating: (18)
I will be sticking with the original runner design that Mazworx made since they probably did a bit of R/D when designing it. The plenum design that i have settled on will give me the same volume that Mazworx has, so I don't see there being a problem.
