S14 will not start
I've got an s14 that I've done a swap where I took the motor, trans, harness, and ecu out of an automatic car and put the motor, harness, and ecu with the car's original manual transmission. I used the lower harness that was in the car and pulled the motor harness because the previous owner fucked it all up.
I've got it all in the car and plugged up right as far as I can tell but I get no fire and the fuel pump doesn't prime.. its open header right now too with no o2 sensor in the header (didn't have one its an aftermarket header). So any ideas or steps I could take to figure out what is going on? as a warning its my first swap with a nissan so bear with me...
![]() Join Date: Jul 2010
did you wire up the park/neutral switch? If the car was Automatic and now Manual you have to wire it up, if it was manual and you put an auto harness in, the car needs the clutch switch wired up (both are in different areas) if you search park or neutral switch you should find some pictures of what I am talking about.
#4 | ||
