Old 11-19-2011, 03:28 PM   #91
Sileighty_85
Sileighty_85's Avatar
Went for a short Drive, No vids yet until I get the BOV welded on.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-20-2011, 02:40 PM   #92
EazyS13
EazyS13's Avatar
EazyS13 is an unknown quantity at this point
nice to see it live!!
EazyS13 is offline   Reply With Quote
Old 11-20-2011, 03:53 PM   #93
Sileighty_85
Indeed
Got the BOV welded on and damn she rolls out at .5 bar cant wait to up it to .9 bar
後輪駆動車1番
1986 SR86 - 200ish
Old 11-20-2011, 04:04 PM   #94
s13Kurt
s13Kurt is an unknown quantity at this point
I just found an sr5 shell for cheap, and was wondering if you had any pointers as far as wiring. I also would like to keep the corolla gauges and use a converter.
s13Kurt is offline   Reply With Quote
Old 11-20-2011, 04:31 PM   #95
Sileighty_85
ummmm, There are a few diagrams you can use.
Its ridiculous how easy it is if you know the SR harness pretty well.
I did mine in 1 afternoon
AS for the cluster, it seems you would need a Signal converter for the Tach and a an Older Z car VSS not sure which one
後輪駆動車1番
1986 SR86 - 200ish
Old 11-20-2011, 05:23 PM   #96
s13Kurt
^ Thanks alot! How much do you think you have in the swap not counting the shell or motor set. Trying to do this correctly on a skimp budget. Already have the motor set and picking up the car for 400. I have a friend that will let me copy his mounts so I just need metal for them. Wiring is free and drive shaft I can get on the hookup. Still need a diff and have to get a fuel cell because of the carb tank also.
Old 11-20-2011, 07:43 PM   #97
Sileighty_85
You pretty much have it covered, nothing really special needed other than the Mount kit and driveshaft.
Power steering is an issue unless you have a manual rack
後輪駆動車1番
1986 SR86 - 200ish
Old 11-20-2011, 08:46 PM   #98
s13Kurt
Why is it an issue?
Old 11-20-2011, 09:25 PM   #99
Sileighty_85
well you'd have to make some custom lines using the SR power steering pump, if you wanted power steering
後輪駆動車1番
1986 SR86 - 200ish
Old 12-05-2011, 12:44 AM   #100
will_drift_4_food
will_drift_4_food is an unknown quantity at this point
I joined this forum to gain info on doing my own SR86 project, and have found it to be by far the most informative of about a dozen I have since frequented. Thank you to the many DIYers that make this possible. That being said, I would like to post some info that I learned in doing my swap that might not be mentioned here. It is likely irrelevant to most anyone not doing this swap, but I include it because it either very difficult to find on the web, or because I figured it out through trial and error. When I decide to do my own build thread, I will move this information there and link to it, but for now:
The exhaust is a very tight fit, especially with the turbo in the stock position and power steering. I can appreciate all of the suggestions from other on here regarding a workaround, but if you were to look at it you'd say "OOOhhhhh!" And then, " Damn, dude, how ARE you gonna make that happen?" Best suggestion is to use an aftermarket S13 elbow and then use the ol" "cut-and-weld-in-a-piece-of-pipe" trick, or just beat a big dent in it. Bottom line is that, even with a little restriction here, the car is still going to scoot like a raped ape.
I knew that my future plans included a T28 or T30, so I used a top mount manifold and just welded a t25 flange to it. Custom DIY Teflon lines and fittings from Frozenboost.com. Downpipe was tricky, but I've got 3" all the way past the steering shaft. Easiest thing to do is to buy the t25 to 3" v-band adapter and weld an elbow onto it, whether you go top mount or not. Manual steering rack helps a LOT. Manual rack from an AW11 MR2 works, and they are easy to find. The writeup is on club4ag if anyone else is interested. I'll post pics of my 'finished' project when I have a chance.
The wiring is exactly as shown in the diagram, very simple. I mounted my fuel pump relay in the trunk (near the battery), and used another relay in the front for switched accessories like fans and gauges and whatnot. For battery relocation , I suggest a 120A circuit breaker mounted in the trunk. Also provides a binding post for power distribution in the rear of the vehicle.
EvoVIII FMIC fits great. Cold side S13 FMIC piping fits pretty good, just trimmed 6" off of the rear of the lower piping. For the radiator hose, I found a 1.25" OEM hose with some good 90deg bends. Then we used a section of galvanized chain link top rail (yes, fencing) for the center section of the pipe. You could easily weld a bung to it for a temp sensor. We put a 10deg bend in it to allow it to clear the electric radiator fan.
Some Nissan Hardbody pickups had FS5W71(x) transmission with a shorter tailshaft section. Swap the KA bellhousing for the SR bellhousing and the shifter hole lines up almost perfectly. Also, the truck shifter (and extension housing) has a shorter throw than the S13/S14 transmission due to having a longer spindle below the pivot ball. I didn't want to use the long a$$ truck shifter, so I made a hybrid out of the two nissan shifters. I compared the stock SR20 shifter to the stock AE86 shifter, and they are identical. AE86 short throw shifter on eBay comes with a different extension housing that allows them to utilize a longer spindle, and I'll be damned if it doesn't appear to be exactly what I ended up with after several hours of cutting, grinding, and welding.
I find that the 4.3:1 final drive in the AE86 GTS rear end is a bit limiting, even on the street, but I've got a KAAZ 2-way LSD in mine and don't want to spend a bunch more money right now on a custom rearend. When I do (~6-12mos), I will go with a Mopar 8.75" rear and a 3.8x gear. Some Cressida wagons had a 7.5 solid rear axle, and of course there's always the MKI Supra rearend. The AE86 speedometer will still not be accurate, regardless of whether you use the S13 cluster or the 280z speedo sender unless you change the speedo drive gear for a 4.3 final drive. Just buy a GPS and use that for speed readings. Or get a smartphone app. It's much easier.
Very nice budget writeup. Keep up the good work.
will_drift_4_food is offline   Reply With Quote
Old 12-05-2011, 05:51 PM   #101
s13beast
s13beast is an unknown quantity at this point
Got the wiring diagram man. Cant wait to get started on mine.
s13beast is offline   Reply With Quote
Old 12-07-2011, 07:19 PM   #102
EazyS13
EazyS13's Avatar
vids?!!!!!!!! of the car man!!
Old 12-07-2011, 07:42 PM   #103
Sileighty_85
Do work!
I'll try to get some this weekend, been sick and weathers been shitty
後輪駆動車1番
1986 SR86 - 200ish
Old 12-08-2011, 07:15 PM   #104
EazyS13
EazyS13's Avatar
i feel yaa weather been sucky here as well
Old 12-08-2011, 07:28 PM   #105
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
Owning a 86 myself and doing a VQ motor swap I cant see how we went so long without doing awesome motor swaps in our chassis for the same cost as 140hp 4AG. Props for doing this swap yourself and making it reliable, good work!
Tryangle
Slip Gypsies Blog
not sure if you realize this
Old 12-22-2011, 08:26 PM   #106
Sileighty_85
Tryangle
haha a VQ will be nuts.
Thanks
Little work
Got in my Spare 3rd member and swapped in the TRD Diff.
後輪駆動車1番
1986 SR86 - 200ish
Old 02-19-2012, 12:55 AM   #107
Sileighty_85
slow progress due to work.
Ordered a T3 panhard bar and waiting on my Tax return so i can order some Stance Coilovers for it
後輪駆動車1番
1986 SR86 - 200ish
Old 02-19-2012, 01:20 AM   #108
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
Wow, how did I miss this thread. Keep up the great work it is motivating to see some diy stuff. Good job.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 02-28-2012, 05:03 PM   #109
Sileighty_85
Thanks, Off topic is pretty much in the dark.
just got in my adjustable T3 Power Steering Knuckles for more angle. Holy Shit they are beefy.
Also Ordered Stance Coil overs last week so hopefully they will be in this week.
後輪駆動車1番
1986 SR86 - 200ish
Old 02-29-2012, 06:54 AM   #110
meme2105
meme2105's Avatar
meme2105 is an unknown quantity at this point
Send a message via Yahoo to meme2105
very nice build.... you got me motivated to go out and do work on my car....nicely done sir
meme2105 is offline   Reply With Quote
Old 02-29-2012, 10:17 AM   #111
Sileighty_85
Thanks, Glad I can help haha
Just got these in!! BALLER!!
後輪駆動車1番
1986 SR86 - 200ish
Old 02-29-2012, 12:27 PM   #112
cgtdream
cgtdream's Avatar
cgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond repute
Great thread man...would say keep up the good work but it looks like you got things covered...in other news, i remmeber you from oki....for some reason i got pics of your car on my photobucket...
Juicy slayin aint easy, but dammit somebody has to do it!!!
cgtdream is offline   Reply With Quote
Old 02-29-2012, 12:57 PM   #113
Sileighty_85
Thanks,
Haha Nice I miss that car, Just wish the PO didnt rattle can the car.
後輪駆動車1番
1986 SR86 - 200ish
Old 02-29-2012, 05:29 PM   #114
Pinggg
Pinggg's Avatar
+1 for Stance coils!
Old 03-01-2012, 03:01 AM   #115
blitzkrgCT9A
blitzkrgCT9A's Avatar
blitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond reputeblitzkrgCT9A has a reputation beyond repute
sick ass build!!!!
subscribed!
blitzkrgCT9A is offline   Reply With Quote
Old 03-01-2012, 05:42 PM   #116
Sileighty_85
Thanks Guys, I got the Rear setup installed and Feels soo much better
hopefully able to instal the front sometime this week
when I was doing the rear I noticed how bad the rear axle twist from being lowered so gonna have to probably get the 4 link setup as well :/
後輪駆動車1番
1986 SR86 - 200ish
Old 03-05-2012, 01:50 AM   #117
Sileighty_85
Got the fronts installed.
Chassis handles sooo much better now
後輪駆動車1番
1986 SR86 - 200ish
Old 03-05-2012, 07:20 PM   #118
EazyS13
EazyS13's Avatar
wish i could "stance" lol
Old 03-09-2012, 11:09 AM   #119
Sileighty_85
Ordered a rebuild kit for the the Hachi's rear axle and front wheel bearings and Ordered a Beefy ass solid Pinion Spacer from Weir Performance. 3X stronger than OEM
後輪駆動車1番
1986 SR86 - 200ish
Old 04-13-2012, 11:06 PM   #120
Sileighty_85
Still waiting on the diff to get shimmed. :/
Also sent my Hoshino Rim off to get repaired
I must say this is the Most ive ever been impressed by a shops work.
Thing is beautiful. Normally they would clean/polish/repaint the rims but i told him not to since it would make the other 3 look like shit haha
Shop's name was Rim Spec in TX
後輪駆動車1番
1986 SR86 - 200ish
