#32 |
![]() Join Date: Jan 2009
ok so instead of taking out my egr and cleaning it i got another catalytic converter and hooked it to my car and took it to a smog shop(a no pass no pay place) to see how the new numbers will look...turns out i still failed due to high nox at both speeds only went down about 200..
so after avoiding removing and cleaning my egr looks like i have to..and ive read that retarding the timing will reduce NOx numbers..this is correct? and how much can i lower it without damage..
![]() LOVIN ME TOOFODEE!! |
#33 |
Sorry to be a smartass, buy why ask for help if you don't want to hear any solutions? I still say check out the EGR system. It may not be that the valve itself is clogged, it may just not be operating at all. Who knows. That would still be the best place to start unless you want to keep throwing parts at the problem. If it is all good, at least that will be eliminated from the very good possibility list.
#34 | |
oh no doubt im going to take apart my egr..i just wanted to rule out the catalytic since its easier to remove than the egr..but now im just wondering if retarding the timing will help me out lowering the NOx level along with cleaning or replacing the egr..
#35 |
![]() Join Date: Jan 2004
when my state still had emissions testing, i once unplugged an injector and let them run it on three cylinders to pass with flying colors.
#36 | |
r u serious?will that actually work?
#38 |
okay so i ended up taking apart my egr and cleaned the hell outta it..it was filled with alot of black carbon crap and i ended up buying a brand spanking new catalytic converter and changed my o2 sensor..my results were:
15mph HC.....max=88.....measured 30 cO.....max=0.52...measured 0.03 NO.....max=704....measured 27 25mph HC.....max=53.....measured 16 CO.....max=0.50...measured 0.04 NO.....max=738....measured 5 finally passed with Flyin colors...thanks everyone for their suggestions and output!! ![]()
#42 |
=P All I'm saying is if you had to replace it once you will have to again. Everything fails at some point. That is why I'm so gungho about diagnosing problems. If you replace something that hasn't yet failed you miss out on some of its usable life and the new part will fail at some point as well.
#43 |
FreshColdBeer.com
![]() Join Date: Feb 2008
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Your nox levels are high because something in your setup is causing it to run lean and therefore increasing the combustion temps, also you want to fill up 91 octane, maybe buy a new cat and clean the egr, or you can write down the cost for all this, and compare it to paying for a dirty smog and go for the cheaper of the two.
But I recommend you go the legal route |
#44 |
Congrats on passing your emissions test. About your knock sensor code. You were getting it because you were running 87 regular gas. The dohc 240's need to run 91. You can run 87 but the sensor will detect knock, throwing the knock code, and retard the timing
#45 |
ha ha ha. i capped off my EGR with a chunk of license plate, and i'm about to get an exhaust fabbed up from the header back with no cat.
god i love not dealing with bullshit
#48 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I pulled out my egr after running seafoam through the throttle body and found carbon caked inside the manifold.
My egr solenoid had no ground and the vacuum hoses were melted back there on an SOHC. |
#49 |
Failed again 3x
I just failed for the 3rd time.
After the 2nd time: I replaced the spark plugs and plug wires, O2, EGR solenoid, cleaned out the EGR ports, 2 new fuel injectors, new vacuum hoses, and the MAF. 15mph NOX 2803 25mph NOX 1276 15mph CO .87 Do you think a new cat would fix all of this? |
#50 |
![]() Join Date: May 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
change your motor oil helps reduce nox. new oil helps the motor work less and creates less nox.
where i use to live use to have smogging and i failed on NOX so i changed my motor oil and went back and passed with flying colors.
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
#52 |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
Are you getting any codes at all? How's your idle?
Typically when a cat is bad all three areas are higher than normal.
- Jimmy Wanted: TBD For Sale: TBD |
#54 |
Damn smog suck's, I kept failing so I figured it had to be the air idle control valve or whatever that things called that everyone takes out. So I took the pipe off that attaches to the exhaust, put a nickle in there then reattached the pipe and walla, I passed! Just thought id share what I had to do.
#56 |
![]() Join Date: Sep 2003
![]() Feedback Score: 10 reviews
my 240 years ago didnt pass for shit. found out the cat was gutted lol . New cat and had teh egr replaced and it passed. failed was GP over 3000's , passed in the 110's
#57 | |
#58 |
i gotta friend who will just pass your car even if you failed already but it cost about $300 not bad considering you might pay to get what you thought was the issue fixxed and have your car fail again lol
#59 |
#60 |
I know a new cat will make the car pass.......but Gold Shield gives them out last after they do everything else. And since I'm running rich---the cat would go out in 3 months.........so I might as well fix the richness and stop wasting gas.
| Tags |
| 240sx, s13, smog |
