Old 11-18-2001, 11:04 AM   #1
gh6o6
gh6o6 is an unknown quantity at this point
well i found it but i cant get through the rubber seal. how has everyone done this any info will be good
thanks
gh6o6 is offline   Reply With Quote
Old 11-18-2001, 11:50 AM   #2
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Personally, i ended up having to drill through the firewall. It's a bit of a pain, but it works. Make sure you have the right size drillbit and a grommet to put in there though... that's where I ran into a problem. I didn't have the right size bit, so the grommet didn't fit. I've still got to fix it somehow.
transient is offline   Reply With Quote
Old 11-18-2001, 01:19 PM   #3
gh6o6
whered you drill the hole?
Old 11-18-2001, 11:36 PM   #4
transient
transient's Avatar
Well, on the S13, there's what looks like some sort of drainage thing on the passenger side. I went a little below that and drilled the hole. I doubt your car will be the same though... Basically just try to find a place that's out of the way and away from engine heat.
Old 11-19-2001, 09:20 AM   #5
IceTekGuy
IceTekGuy is an unknown quantity at this point
You found the hole, but didnt know what to do with it, tsk tsk tsk...
personal problems should stay personal...
<img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
IceTekGuy is offline   Reply With Quote
Old 11-19-2001, 10:49 AM   #6
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
try to find the holes from your engine bay
it is easier
drifterx is offline   Reply With Quote
Old 11-19-2001, 11:22 AM   #7
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Its ez to see in the engine bay, just look where your passenger side is and you should see a black rubber peice that will allow for wires to be droped through. I ran my fogs through there a long time ago. You can get to it also by the passenger seat where your feet go you should be able to see if you pull back the carpet. Stick a screw driver threw and you will be able to see where it is in the engine bay.
West is offline   Reply With Quote
Old 11-19-2001, 04:23 PM   #8
gh6o6
i tried the dam things sealed tighter than a ... well nevermind
