Old 05-27-2015, 06:26 PM   #1
<^> ^_^ <^>
<^> ^_^ <^> is an unknown quantity at this point
FS: 2002 Audi A4 stage 3
For sale: 2002 Audi A4
Mileage: 197000
Price: $6500 Edit: lowered price
Contact: [email protected]
I'm only the second owner and have maintenance records for everything
Full power everything with heated seats. AC and heat works.
Email for faster response.
Edit:I added some more pictures of the receipts and paperwork that i have for the maintenance and parts for the whole life of the car
Unitronic tuned K04
440cc injectors
Upgraded Coil Packs
6k HID kit/Yellow Fogs/HID rear license plate lights.
KMD catch can
ASP Tuning FMIC
Miltek Cat-back Exhaust
034 MotorSports Test Pipe
AWE Tuning Boost Gauge
Upgraded motor,transmission, and rear differential mounts
StopTtech Stage Brakes w/ Slotted Rotors and Hawk Brake Pads
Stage 4 Clutch and flywheel
Timing Belt Service recently done, as well as oil change.
Solid metal protective vented skid plate
Morel Maximo 6" Components (front)
Morel Maximo 6" coaxial (rear)
Helix E8W subwoofer
Grom Ipod kit
Helix Blue 5 channel amplifier
30% Tint all around with 20% tinted rear window.
18" Inch RS6 Wheels Reps from Achtuning w/ all season tires
Brand New OEM floor-mats
Brand New OEM Air Filter
Brand New OEM Rear seat cover/liner.
Replaced both front axles, a year ago.
just installed a new stage 4 clutch and flywheel around 6 months ago.
Replaced the injectors with all new green giant injectors.
Replaced the MAF sensor 6 months ago
Replaced the rear brake rotors and pads a year ago
Replaced the hood release latch 10 months ago
Replaced the power steering line a year ago
Opened up the engine and cleaned the insides of sludge buildup
Replaced the ABS sensor
Replaced the HID's 1 month ago
Replaced the coolant overflow tank 5 months ago
Replaced the oil level sensor 5 months ago
Bads
The driver side seat is wearing down a little bit, but all the rest of the seats are in mint condition
Some of the buttons are showing the infamous peeling button problem. Just need to buy some switches off of amazon
Weak e brake
Although this car has a lot of miles on it, I know it can go for another 100000 miles. I've fixed every check engine light that came on, replaced all the sensors that usually go bad. I have records and receipts of every part and service that has gone into this car since 2002. This is a solid car.
Price is OBO
#/f/showthread.php?t=21036
<^> ^_^ <^> is offline   Reply With Quote
Old 06-01-2015, 06:02 AM   #2
<^> ^_^ <^>
Price is OBO
Old 06-02-2015, 08:59 AM   #3
hellion240sx
beautiful car.
hp? awd?
240 addict miata addict
Old 06-02-2015, 09:44 AM   #4
<^> ^_^ <^>
Its awd, hp is estimated around 270
Old 06-12-2015, 09:34 AM   #5
<^> ^_^ <^>
Bump, i can email anyone more pics
Old 06-18-2015, 08:23 AM   #6
<^> ^_^ <^>
Bump price is OBO
Old 06-22-2015, 08:55 AM   #7
<^> ^_^ <^>
to the top
Old 06-24-2015, 05:38 AM   #8
<^> ^_^ <^>
If i can sell it by this week, i will lower the price to 7300 AND throw in a almost new GT28RS turbo!!
Old 06-24-2015, 08:36 AM   #9
Rado
Rado's Avatar
Rado is an unknown quantity at this point
good price! This should sell pretty quickly. GLWS
Rado is offline   Reply With Quote
Old 06-25-2015, 08:14 AM   #10
<^> ^_^ <^>
Thanks! to the top
Old 06-26-2015, 05:37 AM   #11
<^> ^_^ <^>
Just added new pictures of some receipts and compression test that was done before
Old 07-02-2015, 06:42 AM   #12
<^> ^_^ <^>
Lowered the price
Old 07-06-2015, 06:27 AM   #13
<^> ^_^ <^>
To the top! Car is super clean! AC blows hard!
Old 07-08-2015, 06:14 AM   #14
<^> ^_^ <^>
Lowered price again!
Old 07-13-2015, 10:05 AM   #15
<^> ^_^ <^>
To The Top
Old 07-20-2015, 09:01 AM   #16
<^> ^_^ <^>
To the top!
Old 07-23-2015, 09:47 AM   #17
<^> ^_^ <^>
bump it up
Old 07-23-2015, 10:20 PM   #18
Cheebahawk
Cheebahawk is an unknown quantity at this point
You post this on Audizine and vwvortex as well? Probably get more bites there if you haven't yet.
Cheebahawk is offline   Reply With Quote
Old 07-24-2015, 07:17 AM   #19
<^> ^_^ <^>
Ok thanks for the info
Old 07-28-2015, 06:40 AM   #20
<^> ^_^ <^>
to the top
Old 07-30-2015, 08:13 PM   #21
<^> ^_^ <^>
Just got it inspected and checked for any leaks. there was a coolant leak so i got a new t stat housing as well as sensor. Also checked the turbo for any oil leaks. Everything is clean
Old 08-07-2015, 07:57 AM   #22
<^> ^_^ <^>
Lowered price again
