11-29-2010, 12:57 PM | #1 |
gt2871r coolent line fitment problem
I have a 2871r and I'm trying to install these upgraded turbo line but the cooling line on the wastgate side I hitting the wastgate rod I have tryed it a few way and it seem to really only go together one way is it possible I have the wrong lines ?
11-29-2010, 02:24 PM | #3 |
You are supposed to be using the wastegate with the U bend in it. You can turn the wastegate rod with your hand for clearance. Also, the coolant line (if aftermarket) you use the side with the 90* bend in it.
11-29-2010, 02:34 PM | #4 |
Ok It looks like I hooked the straight end to the turbo coming straight out over the actuator arm towards the strut tower. Then I looped down under towards the engine block If that makes any sense. I have DIF lines.
11-29-2010, 06:58 PM | #5 |
My wastegate had the bend in it that's why my line fit over the top. I didn't try to turn it though. Worked fine for me the end with the 90 is on the block
