![]() Join Date: Oct 2009
Trader Rating: (38)
Hey whats up guys . so im sure there is threads on this and info but there is a lot of difffrent info on which i should go with before i begin my swap into my 89 coupe. it currently has a single cam!
basically im picking up a 97 ka complete motorset with ecu and harness. -My ?s are can i just drop the whole motor and do plug and play without having to change anything to the motor? like intake mani and dizzy.????? -also for the cluster i know i have to get a dualcam cluster. would it read properly me using the 97 harness and Ecu or is it gonna read it wrong? any wiring i can do to make it work.??? i would really appreciate any output on this. and i know theres a lot of info but dont know if its correct info or not . thanks! Eric |
![]() Join Date: Aug 2005
it will be bolt on, just get the Dual cam cluster, and Bring me both of your engine harnesses. I will give you one that works. also make sure you get DOHC power steering lines.
or you can just get a 91-94 ka24de engine harness and it will plug in. also swap over to s13 ka24de intake manifold so you can get rid of all the odb2 garbage on it.
i suggest going OEM as possible. no need to hack up the 97 ka engine harness to make it work with your car. saves a headache for the next person that works on that car.
![]() driftingisgay.com |
#4 | |
Intake manifold swap Exhaust manifold swap Distributor Swa AIV equipment to be brought over. S13 Ignition coil and brackets its easier to just wire up the 97 harness. |
Trader Rating: (38)
yeah thats the reason why i would rather stay obd 2 cuz i dont wanna go through swapping all that lol
an juandizzle so i just bring you my sohc harness and the dohc harness? your gonna rewire? |
