| South Eastern States Alabama, Florida, Georgia, Mississippi, North Carolina, South Carolina, and Tennessee. |
Complete S14 KA24DE Turbo Kit
If this is listed in the wrong location mods please correct my mistake.
I live in the Atlanta, GA area so an Atlanta pickup would be preferred. If you buy this turbo kit and it needs to be shipped I will split the cost of shipping with you. Payment can be cash or PayPal. This is going to be the most complete S14 turbo kit you see offered. The following parts are included in this turbo kit so when I say complete I mean complete. Please note that these parts are used but the pictures that I have a stock pictures. I will be uploading current pictures in the next couple of days. · R.S. Enthalpy Tune with Wiring Harness: This tune was developed with the following parts in mind. · FiveO 550 injectors from Enjuku: I have a printout with this data on it. The wiring harness has a lead for a wideband (AEM AFR). 11.5 Ohm Dead Time [email protected] Volts Dynamic Flow Dynamic Flow Static Flow Static Flow Static Flow Balance Test Balance Test cc/min cc/min 3.5 cc/min 50% Duty Cycle 25% Duty Cycle 4 BAR 3.5 BAR 3 BAR 6000RP 5MS 6000RP 2.5MS 661 610 560 250 112 661 610 560 250 112 661 610 560 250 112 661 610 560 255 112 · Z32 N62-MAF · CXRacing Kit: TRB-KIT-S13-KA24DE+GA-WT-7702: The kit is supposed to be good for 350hp with injectors and a good Tune. The kit is producing 13lb of boost. http://www.ebay.com/itm/370150622944...witem=&vxp=mtr T3/T4 Hybrid Turbo, Turbo T3/T4 T04e with a 3 inch inlet design 50 AR Compressor .63 AR Turbine Oil Feed and return with kit installed 304 Stainless Steel Top Mount manifold 38mm Wastegate 3" Stainless Downpipe and mid pipe connect s to 3" Cat-back System BOV and BOV Flange Pipe/Non recycling CXRacing Installation Guide · Walbro 255 Fuel Pump · GlowShift Oil sandwich plate: OIL FILTER SANDWICH ADAPTER for KA24DE · Earl's Turbo Oil Return Drain Line · Godspeed: 95-98 S14 240SX KA24DE TYPE-GD INTERCOOLER KIT: http://cgi.ebay.com/ebaymotors/GODSP...item588e2e14bc INTERCOOLER SPEC: max horsepower capacity: 650-700hp core length: 24" core height: 12" core thickness: 3" inlet / outlet size: 3" end to end length: 30 1/2" I don't want to part out this kit because everything that is here was meant to be together. If you don't like the price please keep your negative comments to yourself. Mods please give me until midnight tonight to post pictures of all of the parts. Price $1100 or best offer. Contact me via PM I will be checking it throughout the day. |
