![]() Join Date: Apr 2005
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
S14 a/c fan only works on highest setting
My 96 240sx a/c fan only works when it is on the highest setting #4. 1-3 doesnt turn the fan on. Ive had this on some other 240s ive owned but never knew why. Is the Climate Control unit itself broken?
Same problem here! Need fix as well. on a 97.
I was told it's a bad resistor? Full blast(4) dosent need any voltage resistance so that why it would work??. Like I said though, that's just what someone told me. I'm sure im completely wrong! |
![]() Join Date: Sep 2009
No. I would actually agree with you. Most cars/trucks do have resistors for the blower. Most people think it's from slow to fast but it's actually from fast to slow. The resistor limits the power running through the circuit to make the blower turn slower. I would assume this would be the same case for the S chassis but not 100% sure.
It shouldn't as it needs it's own housing due heat. I believe on the S13 its' right next to evap behind the glove box. I think it's a 4 wire and should also be connected to the blower.
![]() Join Date: Dec 2002
We've talked about this for over a decade kids.
Blower resistor. About $20 new. Mounted to the bottom side of the blower case. Search next time.
I thought i was having this problem too, took out the blower motor and it turned out that the foam "gasket" was getting stuck to the fan causing it to stop spinning. So I removed the foam and its perfect now! Freezing a/c on "1"
![]() Join Date: Jul 2006
is there a way to tell if the resister is blown visually?
also, what makes the resister blow? am i some how drawing too much power or something? i dont wanna buy a new one then blow that again... =\ |
![]() Join Date: Jun 2011
So the resistor pack is the one with the blue wires? Also my heater can work on high without the fan getting stuck, or the fan completely stop everything?
![]() Join Date: Apr 2008
on my s14.......the plug was unplugged for some reason by the previous owner for the "credit card" looking part, Only speed 4 worked, i plugged it in and all speeds now work
#19 |
![]() Join Date: Nov 2001
Rockauto.com is where I got mine. I forgot which one I got but it worked fine.
AIRTEX / WELLS Part # 3A1162 {#2715041B00, JA1216} $22.99 STANDARD MOTOR PRODUCTS Part # RU216 {#2715041B00} Intermotor $23.79 FOUR SEASONS Part # 20131 $28.79 |
