very clean black 1997 s14 with stock s13 sr20det setup
SOLD SOLD SOLD
only trades would consider is for a AP1 S2000 for serious inquires my cell phone is 732 762 3203 car is located nearby englishtown, NJ 08857 Chassis: 1997 240sx se 93931 miles on chassis approx 6000 miles on motor no rust stock body was repainted oem black in 2007 with oem front kouki lower lip spoiler 6000k HIDs Motor: Stock S13 SR20DET with fully functional A/C conversion fresh stock rebuild with all new oem components prior to motor swap new oem piston rings, main bearings, rod bearings, thrust washers, and timing chain components, gaskets, and seals engine block honed and cleaned cylinder head surfaced and valve seals replaced Red Wrinkle powdercoated valve cover ARP headstuds Cometic Headgasket Apexi Intake HKS wastegate actuator set to approx 10psi Isis Front Mount Intercooler with Isis Hotpipe with HKS bov Brand new Wiring Specialties.com Wiring Harness Koyo N Flow Radiator DIF Fan Controller Flex a lite dual fans Greddy Oil Catch Can BRM catback exhaust RS Enthalpy flashed ecu for stock t25 turbo AEM wideband gauges, VDO boost, and VDO water temp gauges Drivetrain: Gram Light 57 Maximum Gunmetal 17x9 et22 245/40/17 Dunlop Direzzas Star Specs with 80% treadlife Kaaz 2 way LSD with 4.6 ring and pinion (8000mi) and Greddy Diff Cover KTS coilovers Tein front and rear strut bars SPL tension rods with brake cooling deflectors Suspension Techniques front and rear swaybars Powered By Max rear Camber arms Powered By Max rear Toe arms South Bend Clutch Stage 3 Fidenza Lightweight Flywheel StopTech Big Brake update ST-40 with Porterfield R-4 brakepads Cons: will need a new stock t25 turbo due to oil seals have started to leak and exhaust smokes alittle at idle. I've owned this car since 2006 and been built to perform flawlessly at autox and HPDE track days, and have been drifted occasionally. This car is an ideal candidate for anyone looking to go big turbo upgrade on a very clean chassis and freshly rebuilt stock block. Last edited by F1tuner; 10-27-2011 at 06:39 PM.. |
Turbo s2000
Hey man,
Beautiful 240 you have! Ive got a turbo 2003 s2000 which i saw you were interested in a possible s2k trade. Check this link about half way down the page. There is a description of parts and a few pictures. Car has 400whp and is a blast to drive. Let me know if you would be interested. Thanks How much power does you car put down? How much boost were you running? Any issues with the car at all? Rust? Thanks again #/f/cars-sale/399948...ual-trade.html |
