![]() Join Date: May 2010
fuel pump not turning on
hey i have a 92 s13 with a sr20 in it. i have been driving it now for about a year with no problems. i found a shell with no rust so i put my motor in the new shell witch is a 89. now i got all of it in and everything is working but the fuel pump wont prime. like it will crank but not turn over. i think it might have to do with the wiring cuz its a brand new walbro 255 pump. i think it might be the plug from the wiring harness to where the plug is under the dash. but not sure. i also suck with wirimg. if anybody can help ill be so thankful. im going to be away from a computer for a few days so if u could just call or text me that would be awesome (401) 486 3869. or u can email me at [email protected]. anyone would be great. please please help.
thanks my names matt |
As long as your fuses/relays are good, it's all in your wiring. I had this issue when I swapped from a turbo silvia to a non-turbo silvia, I ended up having to swap ALL of my wiring...even behind the dash. Not sure how it is for a 240sx but I would swap EVERYTHING that you have...your issue is more than likely in the wiring somewhere.
yea its not the fuse or the relay. its from the ecuto the pump.. thats where the problem is cuz i used power and groudtothe pump an it works. do u know where i can find a pinout diogram for the fuel pump plug??
