Custom AC installation???
I bought PBM intercooler kit, and with this kit in to install it the ac condenser needs to be taken out.The reason i bought is, bcoz of the shorter pipes which i want faster spool up with more response and along with better engine cooling since all the air that flows into the radiator doesn't flow through the intercooler first... Just wanted to ask if anybody on here had any luck customizing air condintioning being put back in their car? I was considering using a condensor out of a Honda CRX or something and having lines made to fit. From what I've heard and seen they are half the size of a 240 condesor so it could go in front of the intercooler and to one side and really wouldn't effect airflow much when on or off. please enlighten me on how you gus were able to retain your ac! thanks!
![]() Join Date: Jan 2007
Considering that the pbm intercooler doesn't get much (if any without ducting) air flow at all due to its high mounted position your better off putting the condensor below the intercooler.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
