| Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34. |
Alright so long story short I am running a z32 na trans on the back half of my 1jz vvti in my 89 s13, I got my shifter bracket and stuff finally in the mail today and my shifter linkage/ujoint coming out of the trans is twisted, rotated about 15 degrees clockwise, I thought this was normal at first until I installed my shifter and looked at pictures of other z32 transmissions, and was locked out of most my gears unless I forced the bracket to twist a bit, but regardless I'm not sure if the ujoint will twist back if I use a pry bar or something or if the problem lies internally in the trans
Here are some pictures of it Album link: https://imgur.com/a/DgHsCiD |
