**5spd conversion parts that are interchangable for s13 and s14
So I need to know if any of these parts can be used on an s14 chassis if the parts came from an s13:
5 speed Driveshaft M/T harness (Will mod my A/T wiring if I really have to) M/T crossmember clutch master cylinder clutch slave cylinder Clutch hardlines Clutch rubber line and dampener line Clutch pedal assembly Shifter assembly (plate, lower rubber boot, finisher plate)e brake pedal assembly (or I'll just cut mine if i have to) Thanks zilvia |
AFC #1
![]() Join Date: Oct 2003
Drivseshaft will not work.
Mod your AT harness. Get a S14 MT VSS. MT crossmember will work, AT won't Slave and master are the same. Hardlines are similar enough to work. Don't use the damper. Clutch pedal is different. There is a spacer on the S13 firewall that is on the S14 clutch pedal bracket. Lower/body shift boot and plate fit. Upper/trim boot is s14 specific. Brake pedal is a bitch to swap.
