Air bag light flashing in Stock '95
The airbag light starting flashing a year ago. It started when I started the car and I heard a click click noise when it happened. Was also having hesitation while this click noise would occur. That click noise fortnately has been figured out. The fuel pump relay was cutting out because the ground from battery to engine was corroded and has now been replaced and all grounds on engine harness have been cleaned. Engine no longer cuts out.
Fuel pump relay works fine now but air bag light still flashes and flashes continuously. I did the reset and it is now flashing much slower with a 1 then 2 flash and starts over. I assume it's now giving a code. I guess it could just be a coincidence that the problem started with the battery ground cable issue or could it have damaged the module. Any idea's
Thanks
z32 front brakes, spl tc rods
