s13 vibrating problem need help!!
i have a 1990 s13
i don't know why but everytime im in 1st or second gear when i take off anywhere before about 2200 rpms my car makes a rumbling noise and my shiftier nob shakes really bad and it is only getting worse!! what is the problem if i need to i can take a video and post it. |
![]() Join Date: May 2011
I'm assuming you have the stock drive shaft? I had really bad shaking from my trans/shifter area and my drive shaft was completely dead. check the joint between the 2 drive shafts, and where it connects to the trans. because they're rubber they aren't very strong.
the drive shaft will thump any time you're accelerating. check out where the drive shaft parts meet, and where it connects to the trans make sure theres no play or anything. you can see if you have a welded diff that the weld broke and is swimming around, if you do a burnout and both wheels leave marks.
I have this same problem. I normally have to launch @ around 2K. So it might be the drive shaft joint? Also sometimes when I shift between any gears, the car does this thing where it jerks the rear end like 3 times. It's almost like the feeling when you do a bad shift.
It's probably either the drive shaft or some gears in the diff are fucked up. The drive shaft is easy to inspect. Just jack the car up and check where it connects to the trans and where the 2 drive shafts meet. Thats where mine went bad. But you could have to go at 2k because some gear teeth are damaged. But I don't know a whole lot about diffs I haven't taken one apart.
