Old 06-03-2008, 02:16 PM   #1
ping
ping is an unknown quantity at this point
SR sr20det won't run good i am stumpped
Ive been working on this for 4 years and i had to rebuild my motor i just put rings and bearings arp fastners and studs. any ways i have a power fc and i cant get the ignition timing right.
also my car went from having -15psi vacuum when i first started it.... a few days later its at 0psi idling.
i have a lap top interface and i up loaded enthalpy base tune, i have it set for 740cc injectors, z32 maf.
a ton of air comes out of the bov (synapse Synchronic) at idle i'm pretty sure its supposed to be vacuum. my bov is set up for recirculated but it seems like the turbo (gt3071r) moves alot of air at idle i also have hks stage 2 264 duration cams
Last edited by ping; 06-03-2008 at 02:27 PM.. Reason: i wanted to mention i had hks cams
ping is offline   Reply With Quote
Old 06-19-2008, 08:28 AM   #2
auk113
auk113 is an unknown quantity at this point
sounds like you have a vac leak. or your throttle is stuck cracked open
auk113 is offline   Reply With Quote
Old 08-26-2008, 08:44 AM   #3
ArmadaJspec
ArmadaJspec's Avatar
ArmadaJspec is an unknown quantity at this point
RB
Fist off you prob should get a certified APEX'i tuner to work on the Power FC they will dial it in exactly compared to downloaded maps (L or D jetro?)
Are you using a GT3071r bottom mount w/ T25/28 flange ??
ArmadaJspec is offline   Reply With Quote
Old 08-26-2008, 09:59 AM   #4
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Yea sounds like you need a tune or the bov is the culprit. If you dont have money for a tune right now borrow a friends bov and see if it persists.
n240sxfnatic is offline   Reply With Quote
