Old 03-17-2014, 10:40 AM   #1
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
Parting out 5 240sx shells, S13 and S14 parts!
Check out my new thread -> #/f/showthread.php?t=607645
Old 03-17-2014, 11:06 AM   #2
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
S13 SOHC cluster?
Arrowking is offline   Reply With Quote
Old 03-17-2014, 11:18 AM   #3
jayy08
jayy08's Avatar
jayy08 is an unknown quantity at this point
can i see the driver door for s14 and center console
jayy08 is offline   Reply With Quote
Old 03-17-2014, 11:30 AM   #4
DJPimpFlex
DJPimpFlex's Avatar
Originally Posted by Arrowking View Post
S13 SOHC cluster?
I don't have a cluster unfortunately.
I'll PM some pics tonight.
Old 03-17-2014, 11:55 AM   #5
sr23det
sr23det is an unknown quantity at this point
what location would you meet up ?
sr23det is offline   Reply With Quote
Old 03-17-2014, 12:04 PM   #6
DJPimpFlex
DJPimpFlex's Avatar
Petaluma, no meet ups. You can come to my place.
Old 03-18-2014, 10:59 AM   #7
DJPimpFlex
DJPimpFlex's Avatar
Bump......................!
Old 03-18-2014, 12:03 PM   #8
Rolo7
Rolo7's Avatar
Rolo7 is an unknown quantity at this point
Is the throttle body a obd2?
Rolo7 is offline   Reply With Quote
Old 03-18-2014, 12:04 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
nah. S13 obd1
Old 03-18-2014, 12:14 PM   #10
sikvic01
sikvic01's Avatar
sikvic01 is making his/her stupidity well-knownsikvic01 is making his/her stupidity well-knownsikvic01 is making his/her stupidity well-knownsikvic01 is making his/her stupidity well-known
I'm looking for the door locks and key for driver side and pass. For a s14. Pm or text me at 8033098744
sikvic01 is offline   Reply With Quote
Old 03-18-2014, 12:22 PM   #11
DJPimpFlex
DJPimpFlex's Avatar
I don't unfortunately.
Old 03-18-2014, 12:28 PM   #12
slider2828
slider2828's Avatar
S14 subframe? Straight I hope?
Turn and Burn!
Old 03-18-2014, 12:29 PM   #13
DJPimpFlex
DJPimpFlex's Avatar
I do have this! Yes it's straight.
Old 03-18-2014, 03:04 PM   #14
Reece
Reece's Avatar
By center console I assume you don't mean the radio bezel? If that's what you have and it has a boot I will buy it.
Don’t price bash me.
Old 03-18-2014, 04:54 PM   #15
banshee_rider909
banshee_rider909's Avatar
banshee_rider909 is an unknown quantity at this point
Shifter bezel for s14??
Sent from my HTC6500LVW using Tapatalk
MmmmmmTACOS
banshee_rider909 is offline   Reply With Quote
Old 03-18-2014, 05:09 PM   #16
DJPimpFlex
DJPimpFlex's Avatar
No that is always broken.
Old 03-18-2014, 07:21 PM   #17
sr20det2010
sr20det2010 is an unknown quantity at this point
Originally Posted by DJPimpFlex View Post
I am looking for a set of quality S13 tension rods (PBM, SPL etc.) Trade?!
Updated the list 3-17-14
(415) 724-0675
Cars
S13.4 240sx truck rolling shell. The truck comes with a bunch of fab work already complete as well as bodywork. I can deliver the shell if needed for extra.
90 240sx hatch
89 s10 rear cab section completely Rhinolined
97 Kouki Fiberglass Conversion front end w multi vent hood
Fiberglass doors
Fiberglass 30mm overs
Mustang Gt rear spoiler
Formula Drift spec roll cage
Rear bash/jacking bar and front lower bumper protector bar.
Quick disconnect Tube Front
Full Aggressive Body kit
Formula D approved fire suppression system
Battery Box
The car will come with stock suspension and wheels. No motor or transmission.
$2600 (price drop) OBO (accepting trade offers, NOT PARTING OUT!!)
Wheels & Tires
2 S14 SE 5 lug Alloys - $100
Engine
SR Red Top Thermostat Housing - $25
KA24DE Throttle Body - $30
S13 SR20 AC Compressor - $50
Apexi Universal Filter - $20
Complete S13 DOHC Power Steering Lines - $120
S14 Power Steering Lines, everything except reservoir - $90
DOHC Throttle Cable - $40
SR20 Flywheel Bolts - $30
S13 KA24DE Fan - $20
S13 KA24DE Fan Shroud - $40
S13 KA24DE Air Box - $20
Drivetrain
S14 Front Cross member - $60
S13 Front Cross member - $60
Kazama Motor mounts - $145
S13 Rear Subframe - $80
S14 Rear Subframe - $80
Clutch Master Cylinder - $15
Clutch Slave Cylinder - $15
Stock T56 shifter - $50
S13 5 speed non abs drive shaft - $70
Suspension
Pairs of 5x114.3 10mm slip on spacers - $35
S14 Steering Rack - $70
S13 Steering Rack - $70
S13 4 Lug Hubs (front or rear) - $35 per pair
S13 Stock rear knuckles with Energy Suspension bushings already pressed in - $75
I have all S13 and S14 stock suspension so let me know what you need
S13 Tension Rod Brackets - $60 (will not split the pair)
S13 Stock Knuckles - $40
Brakes
Z32 Rear Brake Calipers, brembo rotors, carbotech brake pads and conversion brake lines (they have been rebuilt and powdercoated black, everything you need!) - $290
Stock S13 Brake calipers - $25 each
Stock S13 4 Lug Rotors - $10 each
Interior
S13 Cluster Surround - $35
S13 Steering Wheel Adapter (nardi pattern) - $35
S13 5 Speed brake pedal - $40
S13 Rear View Mirror - $15
S13 Center Console - $30
S13 Sun Visors - $25
S13 Gray Carpet - $75
S14 Ebrake Handle - $30
S14 Razo Shift Boot (Black with red stitching) - $30
S14 Zenki Black Face Gauge Cluster - $50
S14 Glove Box, grey or black - $40
S14 Confetti rear seats - $80
S14 Cluster Surround - $35
S14 Grey Carpet - $75
S14 Center Console - $50
S14 Dash, 2 cracks - $80
S14 Climate Control - $30
S14 Interior Mirror - $20
S14 Steering Column Switches (blinkers, windshield wipers etc.) - $35
Aftermarket shift knob (fits 240sx) - $15
Exterior
S13 Hatch Rear Bumper (Have 2, 1 primer, one red) $35 each
S13 Fastback Center Tail Light - $35
S13 Fastback Passenger Side Tail Light - $30
S14 Zenki Passenger Fender - $75
S14 doors - $60 each
S14 Zenki tail light center panel - $35
S14 Zenki Driver Side Tail Light - $30
S14 Side Mirrors - $50
Misc
S13 Hood latch with cable - $25
S13 Upper Radiator mounting brackets - $15
S13 Windshield wiper motor - $10
S13 Gas Tank Door - $15
S13 Hood Hinges - $40
S13 Gas Tank - $40
S14 Radiator Overflow Reservoir - $35
S14 Gas Tank (local only) - $100
S14 Interior Wiring Harness - $120
S14 Steering Column - $50
Polk Audio 4x6 speakers - $20
Summit Racing Roll Cage Mounted Helmet Hook - $10
I have EVERYTHING so if you don't see it post/pm me. All stock parts are available. Shipping is also available on most parts.
(415) 724-0675
hey do you still have the sr20det head red top???
Sent from my SM-N900T using Tapatalk
sr20det2010 is offline   Reply With Quote
Old 03-18-2014, 08:05 PM   #18
DJPimpFlex
DJPimpFlex's Avatar
No I don't
Old 03-18-2014, 08:13 PM   #19
SinCityS14
SinCityS14's Avatar
SinCityS14 is an unknown quantity at this point
looking for the trunk latch on the car side from a s14
G37s - Dropped on DPE 20's - $old
S14 - Bone stock
SinCityS14 is offline   Reply With Quote
Old 03-18-2014, 08:32 PM   #20
seagrasser
seagrasser is an unknown quantity at this point
S14 hood? in black?
S14 RB25
seagrasser is offline   Reply With Quote
Old 03-19-2014, 12:03 AM   #21
gerardojdm
gerardojdm is an unknown quantity at this point
Do you have a S14 clutch pedal assembly?
gerardojdm is offline   Reply With Quote
Old 03-19-2014, 12:03 AM   #22
DJPimpFlex
DJPimpFlex's Avatar
I don't sorry
Old 03-19-2014, 12:55 AM   #23
coty_garcia
coty_garcia is an unknown quantity at this point
Still have the s13 5 speed brake pedal? Do you have stock s13 clutch assembly (pedal, lines, and other miscellaneous clutch stuff) text me 714 400 4115
coty_garcia is offline   Reply With Quote
Old 03-19-2014, 04:27 AM   #24
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
Have S14 door panels? If you do send me a pm
Cronus577 is offline   Reply With Quote
Old 03-19-2014, 05:48 AM   #25
DIENOW
DIENOW's Avatar
DIENOW is an unknown quantity at this point
I need (all for S14):
- The socket AND plug (harness side) for the S14 passenger side bumper marker.
- The windsheild washer tank PLUG ONLY (harness side).
Goofy ass pictures for better explanation:
DIENOW is offline   Reply With Quote
Old 03-19-2014, 10:14 AM   #26
DJPimpFlex
DJPimpFlex's Avatar
^haha I like the pictures dude! Unfortunately I won't cut plugs off the harness.
Old 03-19-2014, 11:59 AM   #27
240low
240low is an unknown quantity at this point
s14 speed sensor??
240low is offline   Reply With Quote
Old 03-19-2014, 02:56 PM   #28
DJPimpFlex
DJPimpFlex's Avatar
Originally Posted by 240low View Post
s14 speed sensor??
I don't have one unfortunately.
Old 03-19-2014, 03:22 PM   #29
jayy08
jayy08's Avatar
still waiting on the pic of s14 driver door
Old 03-19-2014, 03:32 PM   #30
DJPimpFlex
DJPimpFlex's Avatar
