So i am rebuilding my KA after 220 miles, replacing everything piston rings, rod bearings, ect.... and want to know which is the best after market oil pump for it?
You dont need an aftermarket oil pump. If you are worried about starvation/bearing issues, weld some flip-door baffles in the pan to keep the sump pickup submerged at all times and use good motor oil.
Just another broke ass drifter
