![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
S14 I need help solving these isssues.
I have a couple issues with my s14. I need your help zilvia members. My first problem is while I'm sitting at a light, the gauge tends to go up and down. My second issue is there a special tool to use for brake job on an s14 brakes? Also my last issue is my gas gauge it says, full needle which I highly doubt it.
92 s13 coupe all stock 11-29-15 |
#2 | |
There is a special tool for the rear brakes, but a partially opened set of needle-nose pliers works very well. I think it added a net of 5 minutes per side vs. standard disc brakes. |
#4 | |
![]() Join Date: Jan 2012
make sure you turn the brakes clockwise to set them back in.
& for your idle. check the iacv. clean it. check for VACUUM LEAKS!. clean your maf. while your at it buy a fsm, or download one, since you bought it, might as well read it. for vacuum leaks, buy some carb cleaner and spray around the lines, when the engine starts it increase/decrease idle, your know you got a leak in that area/hose. goodluck. |
