Help Me Diagnose Mil To Pass Smog!
So i bought my s14 zenki from a guy i thought was my friend a couple of months ago. He said it would pass smog but it wont because the mil is on and wont go off. These are the codes I'm getting
P1141-Vacuum cut valve bypass valve P0505-Idle air control system P0443-Evap emissions system P0446-Evap emissions vent control circuit P1105-Map/Baro pressure switch solenoid valve Its throwing a few others that come back after a long drive, but these 5 wont clear even right after i clear them with my scanner. Ive tested all the components and found them to be good, so i'm guessing its a curcuit fault. Does anyone know a common circuit power or ground for all of these components, or has anyone experienced this problem that can help me. You guys are my last hope before i give up and take it to a shop, cause registration was up 3 months ago an this is still my daily driver. Any input is appreciated, and thanks. |
![]() Join Date: Oct 2007
check all vacuum lines, I had similar problem, 3-4codes poped so I replaced a vacuum line on the back of the manifold, it was a L shaped line and was kinked at the bend. Replaced it and all 3 codes were cleared.
