I was just wondering what all of you guys are running suspension wise for your 240's. I have a 91 240 and am debating right now on which path I should take. I'm deciding if I should buy an aftermarket shock/spring setup or a coilover system. Maybe after looking at your setups, I'll get a better idea at what I want.
I don't have a lot of money, so right now I'm looking into the KYB AGX and an aftermarket spring. The spring of choice right now is H&R or B&G. I'm looking for a stiff spring. What are your opinions on these? The H&R lowers the car about 1.3 in. while the B&G about 1.5 in. Would this be a good lowering rate? |
AutoX Junkie
Right now I'm pretty much running a stock suspension, but this is what will be under it w/i the next couple of months...
KYB AGX's Eibach ProKit S/T rear sway bar front sway bar from an SE if I can find a junked one f/r STB's |
OMNOMNOMNOM
![]() Join Date: Dec 2000
My new 96 240SX...
SUSPENSION: -HKS Hiper Max Damper II Coilover Suspension -HKS Front & Rear Adjustable Pillow Mounts -Greddy Grex Front Strut Bar -Greddy Grex Rear Strut Bar -Nissan Motorsports Sway Bars -Stillen Adjustable Front Tension Rods -Kyokugen Racing Lug Nuts My Old 91 240SX... SUSPENSION: -5Zigen R-Rate Spring 1.3"Front / 1.1"Rear -KYB AGX Adjustable Shox - 4/4Front / 6/8Rear -Whiteline Sway Bars F-27mm /R-22mm -Stillen Front Strut Bar -Pilot Motorsports Rear Strut Bar -Yokohama A520 215/40/17 -Ingalls Front Camber Kit - Pic 1 -PDM Rear Camber Correction Bushings |
I have seen one site that lists the different spring rates for the different systems. What do you guys think: stiffer springs-->less body roll or not so stiff springs-->better ride?
I would tackle it like this: not so stiff springs with bigger ARB to increase roll stiffness. |
Hey West you wouldn't happen to have the 5 zigen r-rate springs stashed away do you? I wanted to get a hold of those springs becuase I heard they were really good, but I can't get a hold of them. Iheard they stopped marketing them here, but is there anyway I can get a set?
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from WeST on 12:54 pm on July 12, 2001
My new 96 240SX... SUSPENSION: -HKS Hiper Max Damper II Coilover Suspension -HKS Front & Rear Adjustable Pillow Mounts </td></tr></table><span id='postcolor'> What benefit are the rear adjustable pillow balls. With the rear suspension setup of the 240, they can't possibly affect camber, since the shock is mounted to the lower a-arm and not the spindle, and the upper a-arm plus the camber link fix the spindle in 3 places. The only possible benefit I see is on a seriously lowed car, bringing the shock angle back in line. May be a stupid question, but I'm curious. |
