Old 04-11-2021, 10:51 AM   #1
justakouki
justakouki is an unknown quantity at this point
S14 Timing Issue
Hey, I have a built KA-T with an AEM Infinity 5 ECU and a custom WireWorx harness. I'm have a strange timing issues. The car intermittently retards timing. Sometimes I will start the car and it will run and driver perfectly fine, using the timing light it is at 20BTDC where I set it. Other times when I start it it will idle rough with poor throttle response, the timing light shows the timing advanced to 0BTDC. I can start the car back to back in 1 sitting and it could do either of these things. What could cause this?
justakouki is offline   Reply With Quote
Old 04-25-2021, 08:22 PM   #2
LtSlayer
LtSlayer is an unknown quantity at this point
I'm not familiar with that ecu but stock timing is around 15, 20 timing is really pushing especially once boost kicks in, sounds like knock waiting to happen. try setting it to 15 through timing mode. on a stock ecu you disconnect tps and rev to 3k a couple times, this prevents the ecu from varying timing an lets you get a good reference for timing.
can you rev above 3k?
make sure the CAS was installed correctly as well, on SRs there's two dots that can be mistaken. gooddluck
LtSlayer is offline   Reply With Quote
