Hi I am a NooB but did search theres a few topics but just am looking for clarification. Can Side feed 550cc injectors produce 350rwhp safely? be using a Walboro 255lph and straight fit nismo or Toda injectors 550cc with a Power FC on my black top 1994 S14 sr20det.
Looking to keep the engine stock and just add on bolt ons for a nice daily driver. Any relavent help would be appreciated. ![]() |
![]() Join Date: Sep 2002
With proper tuning, yes.
My 240 vBgarage |
![]() Join Date: Mar 2002
I believe 550s will be running pretty high duty cycle at that power level which is why I went with 740s. I dont get why anyone would get 5xx injectors when 7xx are only ~$40 more and offer a lot more room for safe operation.
![]() sentinelguild.com/nzo/PFCDB/ |
Well for idle quality and deceleration reasons mainly, i know people will say if its tuned well blah blah, in reality I have found the right sized injectors for the application will work best. In saying that I think around 370 rwhp is achievable with 550cc's but then thy are begiinning to run a dangerous duty cycle. 350rwhp is the safe limit I am fairly sure?
Cheers guys |
![]() Join Date: Jan 2004
I was going to get 740's for My 275whp set up that I'm building, but some 550's fell in my hands so I'll take it. I would personally not push 550's over 330whp at stock fuel pressure, but I'm a frady cat. 740's wont mess with your idle or deceleration at all if the proper rom tuning is done. You could try some of the rc engineering 650 cc's that Scott from Enthalpy has just started tuning on someone elses car(see FreshAlloy for detail). They are at 363whp on those things safely.
![]() Join Date: May 2003
550cc = 52.4lbs/hr
You have 4 of them... Assume 90% duty cycle as a safe max... Use .55 BSFC... ... [ (52.4 * 4 * .90) / .55 ] = ~343rwhp as a *safe* maximum. The number's don't lie... - Brian
www.KA24DEvelopment.com |
#10 | |
#11 | |
[ (76.21*4*.90)/.57] = ~481RWHP. |
1) Your lb/min conversion is off...you divide "cc" by 10.5 to get "lbs/min".
2) BSFC is up for debate...It varies car-to-car, and depends on A/F. But...I have seen with my car that if you back out the BSFC using a known RWHP and duty cycle (I have done this, from my dynos), that .55 is pretty close. For example... Running 370cc injectors at 8psi, I made ~248rwhp. That was 98% duty cycle, as recorded by a Techtom CMX-100. So....(35.2*4*.98)/.55 = 251rwhp theoretically...pretty damn close. - Brian
#14 | |
i will scan the article I have at home (can't remember which magazine) but they left stock injectors on a 300zx - and were able to get 800+hp (dynoed).
So....why spend money on aftermarket injectors....money can be better spent elsewhere. /my 1/50th of a dollar.
Anyone down for causing a freak gasoline fight accident? |
#19 | |
![]() Join Date: Aug 2004
according to that calculation SupraTTs cant make 500rwhp on 550cc injectors that they have stock... but guess what? they do it ALL THE TIME according to that calculation a stock SC300 can't make 375rwhp on stock injectors... but i've seen plenty make MORE THAN THAT... .55 might be good for a SR20, but by no means should this formula be taken as be-all-end-all for motors... the BSFC rating is very different for all sorts of motors and there are a lot more variables to toss in,such as head design, intake manifold design, motor type (rotary anyone?), octane (RON and MON) of gasoline used, etc personally I wouldnt go over 370whp unless I had race gas, then i'd run it up past 400whp... i'm sure you know all this, i'm stating it for correctness and so some newbie doesnt come in here and take this half-truth as the word of god
95 Lexus SC300 5-speed -DD pimp car 92 Nissan 240sx base coupe -clean KA24DE swapped in -GTIR T28 -Big FMIC -565cc STi Injectors w/ Z32 MAF -J30 VLSD w/ subframe spacers -RPS Max clutch -3" turboback -PLMS Daughterboard on modded ECU |
