Inactive Admin
![]() Join Date: Mar 2002
Stupid Air Conditioning problem.
I keep blowing the fuse that lets the A/C run and lets you operate the power mirrors. I don't know why.
I need ideas. If you tell me to search, I'll smite you. I did search. I troubleshooted. I'm pulling out my hair. It's not an instant blow. It'll run for awhile, and then the fuse will jsut quit. Thanks in advance. |
S13 or S14? Which fuse is shared between A/C and windows on either model? My S14 has a bad driver side window switch... if I leave it all the way down, the motor doesn't stop and continues to run, which has blown the fuse. I just don't remember a link between the A/C and windows.
![]() Join Date: Jan 2003
dunno if it'll help but make sure that the switch on the power mirrors are in the middle so its not giving the mirror power. does the fuse blow if the a/c is off or just when it turns on?
A friend of mine is having the same problem right now. The solution is a coil in the compressor. You have to take the compressor clutch off to get to it and replace it. Problem is we dont know what other coil matches up. At least its a start, wish i could give more info. If we find anthing I will keep you posted.
#10 | |
You always did suck at electrical....don't make me travel all the way to Japan to fix your shorts!!!...HAHAHAHAHA... ID PS: It's probably your trunk dome lights!!!...hehehe...or was it the brakes?? hell I can't remember any more!!!....hahahaha...
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
Inactive Admin
For clarification, the compressor doesn't make any strange sound when engaging, and nothing odd while running.
Diego, yeah I know my electrical sucks. Oddly enough my brakelights are fine now. I'm just pulling my hair out because it's not an obvious short or crossed wire. |
#12 | |
#13 | |
![]() Join Date: Sep 2002
SEARCH!!!!!!!!!!......the junkyard for a new compressor.
Have you tried testing the resistance of any of the components? A short will read 0 ohms if something is shorted which it sounds like. Good luck with it.
My 240 vBgarage |
Bumping this up to see if someone found a fix. Searched everywhere and came up with nothing. Have the same issue and can't seem to trace the problem. 10a fuse blows instantly when I activate the compressor.
Not sure if this matters but my idle doesn't raise like it use to when my ac was working. Could this mean my ficd is bad? Only other thing I can think of is the pressure switch on the drier. For reference, own a 180sx with the original sr20 and haven't touched anything ac related. Just switched out the compressor for another and refilled with freon, work when the tech was filling it up with freon but after he disconnected it, 5min went by and it blew the fuse. |
Quick update: Unplugged the connector at the compressor to see if the fuse would still blow. Started the car and turned the ac on.
Conclusion: Fuse perfectly fine. Does that mean the compressor is bad? Short at the compressor? The connector was pretty dirty/little bit of gunk on it. |
#19 | |
*edit* so I looked around on rock auto, ebay and amazon and didn't see an 'sr20 ac clutch kit' are they universal? or any recommendations where to find them |
