Need some advice on s13 fix
So I got a s13, I traded a sr20 Ecu for it. Anyways I am swapping a v8 in the car and I was inspecting the car and came across a big problem, the tension rod bracket is welded to the frame rail. Only one bracket is welder but I inspected the problem and there is nothing wrong with bolt hole or threaded alignment stud so I do not know why they did that anyways I am thinking about grinding off the bracket and weld and possibly put in a repair piece. Let me know if you have any info or comments on other possible ideas and ways to repair the problem.
Thanks
