![]() Join Date: Jul 2007
Trader Rating: (106)
S13 parts clean out! Misc SR stuff and LOTS of small items!
All parts s13 240sx fitment, all prices OBO. Located in 93065, shipping available for smaller items.
Pic 1 -cometic sr hg, stock bore/thickness- SOLD! -sohc mafs x3- $20/ea -water outlet- SOLD! -thermostat housing- $10 -coolant sensor sub harness x2- $10/ea -knock sensor sub harness w/sensor- $20 -tps- $10 -dipstick tube- $10 -stock turbo pipes- $20 -complete s13 sr intake mani- SOLD! ![]() Pic 2 -s13 sr harness, wired for q45 igniter, w/igniter. Complete uncut harness, needs wiring cleaned up!- $60 -s13 sr lower harness, will work w/240sx- SOLD! ![]() Sr20det aluminum radiator -clean, no leaks, not dirty inside, unknown brand-$50 ![]() ![]() ![]() Pic 3 -juran temp sensor adapter- $10 -small port catch can, baffled/stuffed w/steel wool- $10 -5mm H&R spacers. 4 or 5 lug- $10 ![]() Pic 4 -s13 front LCA?s- SOLD! -maxima tie rods- $20 ![]() Door glass -no damage, blue tint- $40/ea ![]() Pic 5 -washer bottle w/brackets- $20 -5 lug spare- $20 -kick panels- $20 -rear speaker panels (no grilles)- $10 -fr speakers/brackets- $30 -r speakers/brackets- $30 -power antenna w/good mast- $30 -lower tail light metal panel- $20 ![]() Pic 6 -pass power window regulator- $40 -stock rear knuckles- SOLD! -non power antenna base- SOLD! -fuel sending unit-SOLD! -pass door handle- $20 ![]() Pic 7 -sohc throttle cable- SOLD! -KADE idle valve subharnesses, early and late connector design- $20/ea ![]() Pic 8 -antenna harness- SOLD! -manual door harnesses- $20/ both -glove box sub harness-$5 -cluster subharness- $20 ![]() LAST 3 SMALL ITEM PICS: LMK what you need and we?ll work out pricing, too much little stuff to list individually!!! SOLD ITEMS: -dash corner vent -rear ash tray -corner marker light -steering rack bracket -rear suspension bolts ![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by racepar1; 11-16-2020 at 09:29 PM.. |
