s14 cluster / s15 r33 r34 ?
There are models in 1995 s14. I modified my car with the engine Tomei.
s14 cluster structures which can be connected instead? R33 or R34, S15, cluster structures can be used with one to one Functions Do I? |
260Km on the clock and the s14 cluster yeririne 8000 rpm, R33, or P15 cluster 280km 300km from 9000 rpm to take time and I put? Do you sleep in size? warn if size, 9000 rpm runs when you connect the cables? Does anyone know the dimensions? I can get information would be very happy ..
