Old 06-06-2009, 11:20 PM   #1
sred2009
sred2009 is an unknown quantity at this point
T28 turbo lines to S14 SR20DET block
Does anyone have a pic showing the T28 lines (ss lines would be great) connected to s14 sr block? I'm trying to figure out where the oil and water in and out lines that should connects to the block. I don't want to mess it up by connected them wrong. Thanks in advance.
sred2009 is offline   Reply With Quote
Old 06-07-2009, 12:40 AM   #2
Sileighty_85
Sileighty_85's Avatar
its impossible Coolant banjo bolt is bigger then the oil's
the oil feed is located on the bottom left , above the A/C bracket and the coolant line is top middleish
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-08-2009, 08:31 PM   #3
sred2009
ok. Thanks.
Old 06-08-2009, 11:14 PM   #4
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
you cant mix up the oil and coolant but you can mix up the coolant in and out...
HPballer76 is offline   Reply With Quote
Old 06-09-2009, 09:58 PM   #5
bluevelvet
bluevelvet's Avatar
bluevelvet is an unknown quantity at this point
Dude where do you get those Pics in your SIG?
bluevelvet is offline   Reply With Quote
