![]() Join Date: Mar 2006
I have searched and searched on here and can't find the answer. I've went through the FSM, but I'll admit I have serious troubles reading wiring diagrams..
Long story short, the shell I bought had the headlight/front illum pigtails chopped off coming out of the main body harness. I've taken the pigtails off in a chunk from my parts car. I go to wire up the lights and I stopped. Drivers side I have at 3 solid black wires (1 fog light, one turn signal, one corner light), 2 solid black with pink dots (one for H1, and one for low beam), and 2 red with black stripe (one H1 one low beam). The passenger side, I've got 3 solid black (same as drivers side), 2 black with pink dots (one to H1, one to low beam), 2 red with green stripe (one to H1 one to low beam), and 2 red with blue stripe (one to H1 the other to corner light). This has all got me completely confused. My train of thought, would just tell me that all of the solid blacks are just straight up grounds, and they can just get connected up to any of the other solid blacks. But the rest, I don't know if I can just connect them with color for color and everything will work correctly. I don't want to short anything out.
I like beer much the same way as I do cars and women. Light, easy to go down, and preferbly domestic, but now and again an Import is alright. |
![]() Join Date: Dec 2002
Anything black is ground. Period. Some have dots, some don't. Doesn't matter, ground it all.
Blinkers: GREEN/BLACK and GREEN/YELLOW(or yellow/green I forget)
Parking lights: 2 RED/BLUE on each side because there are two parking lights Fog lights: If I remember correctly they are ORANGE and ORANGE/BLACK Headlights: Right Side: High beams are RED/GREEN Low beams are RED/BLUE and RED/GREEN Left Side: High Beams are RED/BLACK Low Beams are RED/YELLOW and RED/BLACK *Every single light has a BLACK wire coming off of it for the ground EDIT: didn't read it properly. A ground is a ground, you can connect it to the other solid blacks |
![]() Join Date: Apr 2006
multimeters are your friend
get one, you can do a simple resistance check to confirm ground leads you can do a simple voltage check to confirm high, low, turn signal and fog leads. simple as that. or, you can wait for people to hand you answers on the forum. :-) |
Well, I'm the first one to admit I'm bad with electrical. So, from what I'm reading, just plug it all up color for color and I'll be OK? I'm not trying to beat a dead horse here, wanting everything to just be correct.
I'm more worried about the Red/Green, and Red/Blue. But from what I can tell on the wiring schematic in the FSM, the H1 and LB both share a wire (guessing it's main power wire). I'll hook it up today and see what I come up with.
On a Zenki the lowbeam is a dual filament bulb, so it will have two wires behind it. Your main concern is not use the red/blue parking feed for a headlight, or vice versa. Everything else matches up fine.
Well, I matched up the sizes and colors of the wires. This is what I have come up with now, this will fry your noodle.
When I just turn on the parking lights, the passenger side corner light comes on and the bumper lights come on. The drivers side corner light does not come on. I turn on the headlights, and all of the lights turn off. No corner lights no bumper lights. When you are looking at the cluster, the drivers side turn signal indicator stays solid whether it is engaged or not. The bright light indicator stays on, when the headlights are turned on, and my headlights do not turn on regardless. All of the bulbs are good. I'm going to have to go back tomorrow and do some testing, ugh!
Grrr, but which one? haha. But seriously, which one did you mess up incase I did the same one?
Bumper lights do not come on at all. Corner lights come on, and stay solid. When I use the turn signal, both of the corner lights flash, both left and right turn positions on the stalk.
I only have one bumper light plug. With it plugged in, the light never comes on, but when I pull the socket off of the connector, my corner lights turn off. And depending on which side it is plugged into, when that turn signal is activated, the high-beam indicator flashes with the turn signal direction. Here are my questions, since it's been around a year since I've watched the front end of a 240. Which lights are blinkers, and which ones only stay solid on the front end of the car, the corner lights or the bumper lights. All of the fuses in the car are good. I went through every single fuse checking them. Both 20a, and the 75a fuseable link are good under the hood. Every single fuse inside the car is good. Does anybody know what I'm missing here? This is a 95' Base model car. Now the car before I owned it, did have a S15 front end on the car. Is it possible there is a relay fried somewhere? EVERYTHING else on the car works as it should, just not the headlights.
I like beer much the same way as I do cars and women. Light, easy to go down, and preferbly domestic, but now and again an Import is alright. Last edited by Ruby240; 04-17-2009 at 04:45 PM.. Reason: Bad description.. |
#12 | |
![]() Join Date: Nov 2006
The blinkers ONLY come on when that blinker is in use no other time do they come on.
92 vert converted 5speed and other little things
Hmm, I could have swore all of the lights attached to the bumper were always on when the lights were turned on.
Which lights blink and which ones don't?
The only ones that blink are the lights on the bumper. Not the ones on the side of the number but the ones that are in the front. The lights beside the headlights come on and stay solid when the parking lights are on and low/high beams are on.
So the corner lights don't blink. Gotcha. My corner lights ARE blinking. All of the bumper lights should illuminate when the lights are on, and are the only ones that blink.
Now to figure out whats wrong. I'm going to have to clip everything again, and start all over. I just don't understand, color for color everything is hooked up correctly, even the size of the wires are matched (the H1 bulb uses heavier gauge wire). I'm beginning to think I have a bad ground somewhere..
Bump? Bump?
#17 |
Well, I think I might have found my bad ground(s) today. Figured I'd just wire up the power and tap the negatives to a good body ground. Wow, headlights came on! I'm gonna go and re-ground my body harness at the headlights here when the rain stops! I'll be so pissed off at myself if everything works right after this. I grounded these good when I got the car home from GA. Maybe I didn't get a good ground there after all... Worse case, I'll wire up some pigtails and find a nice hidden body ground.
no the turn signals the big clear ones on the front bumper DO NOTHING but blink no matter if the lights are on or not.
#19 |
Yep, found that out a lil bit ago when I was looking at nighttime pictures of S14s. The side ones come on but not the fronts. I could have swore my Ruby car they did.. actually I know they did, but I don't know why and it's no big deal. But this entire time I was owned by the two grounds off the harness. Reground them and now the drivers side works perfect. Had another sprinkle, so I came inside. As soon as it stops I'll go hook up the passenger side. I don't work in the rain.
**Edit** Fixed. The two body grounds behind the headlight buckets. Note to everyone, any problems reground these b4 you start pulling your hair out with any problems.
I like beer much the same way as I do cars and women. Light, easy to go down, and preferbly domestic, but now and again an Import is alright. Last edited by Ruby240; 04-20-2009 at 06:02 PM.. |
#20 |
old thread new new question .. a red/green wire and a ground was clipped off my 4 wire connector and i cant seem to fit in into any female connectors around the area , the previous owner spliced a bunch of wires on to wire up the jdm kouki bumper lights no fogs.. any pics of the plugs labeled i cant find anything useful but this thread...
