FS: 1990 240sx - Silvia S13 front end, sr20, etc...
Located in Rochester, NY
Up for sale is my 1990 s13 240sx. Could use paint for sure but runs and drives great, and sr20det swapped aka in better shape than most. JDM S13 Silvia front end. Car is very low and very loud. Lots of aftermarket parts. High mileage chassis but minimal rust for it’s age. Back story is car was originally from Florida and at some point received its engine swap and the Silvia front end. Car then made its way up to ny and I’ve owned it the last 4-5 years. The car has seen better days but has truly been reliable and has never left me stranded. The car could be driven as is or be a perfect project for someone who doesn’t want a car sitting in their garage for years. Either give it a refresh or drive the piss out of it. Car has a few small dings and dents and needs paint, previous owner’s paint job is faded and fenders are primered. The trunk/spare wheel area has some rust holes but mostly clean underneath. The rear of the interior is stripped and the dash is cracked like every 240sx. Other than cosmetics the car drives fine and pulls hard and handles great. Pros: Sr20det swap with t3/t4 Garrett turbo Upgraded injectors and fuel pump Upgraded/adjustable suspension Gram light/rays wheels It’s a black car S13 Silvia JDM front end Rwd car that will do a burnie Butt dyno says it feels fast Car is pretty low Loud as hell Cons: Needs paint job Could use small rust repairs Could use rear subframe bushings Speedo doesn’t work all the time Interior is partially stripped Needs battery hold down Still 4 lug in rear A/c doesn’t work 200k+ miles on chassis Parts list: Red top JDM sr20det -stock motor other than Tomei rocker arm stoppers, as far as I know Touge Factory light weight engine pulley set HKS drive belts Circuit Sports aluminum coolant reservoir tank Apexi air filter with z32 MAF sensor Greddy FMIC and piping Greddy type S BOV NISMO 555cc injectors Walbro 255 fuel pump Tubular topmount turbo manifold, looks homemade Garrett t3/t4 .63Ar turbo, no shaft play Turbonetics external wastegate to uncirculated dump pipe Cat deleted, has test pipe ISIS/ISR dual 3” blast pipes eBay manual boost controller Shaftmasters one-piece aluminum driveshaft New upgraded j30 rear axles (5 bolt) S14 vlsd Megan racing engine and tranny mounts Newer slave and master cylinders Front 300zx aluminum calipers with drilled and slotted rotors, hawk pads Stock rear calipers, EBC green pads and brembo blank rotors Fortune auto 500 coilovers with 9k/7k springs and upgraded top hat bearings (I’d guess 25k miles or so on suspension so could use a rebuild sooner than later) Stock length s14 FLCAS S14 moog ball joints s14 front 5 lug hubs SPL adjustable front tension arms Tein inner and outer tierods with spacers for steering angle Newer reman’d steering rack with energy suspension bushings Megan racing adjustable rear traction arms Voodoo13 adjustable rear toe arms Buddy club bucket seat Parts shop max adjustable shift knob Personal steering wheel Nrg quick release Auto meter mechanical boost, oil pressure, and water temp gauges Aem wideband gauge Blitz turbo timer Battery relocated to trunk, but needs better tiedown Wiring specialties engine harness RS Enthalpy-chipped ECU Front wheels: Rays Gramlights 57dr 17x9 +22 in gun blue Rear wheels: Rays Engineering VXR-10 17x9+32 Tires: square set of Yokohama s-Drive 235/45r17 JDM S13 Silvia front end - oem metal fenders and hood Silvia AERO replica front bumper Triple projector Silvia headlamps Silvia grill has some broken tabs Clear Circuit Sports corner and marker lights Asking $6,300 OBO. Don’t like the price, then send me a REASONABLE offer. NO TIRE KICKERS, NO JOYRIDES, NO SKETCHBALLS, NO TEST DRIVES UNLESS SERIOUS BUYER TEST DRIVE WITH CASH IN HAND, NO PERSONAL CHECKS |
![]() Join Date: May 2007
I see this car at Redi all the time. I often fantasize about owning another 240sx. I imagine that I'd take it to IFD events and englishtown and stuff. GLWS
@be_henney kranstogram is full of nonsense and foolishness. |
| forsale #silvia, s13 240, silvia, sr20det |
