Old 08-27-2014, 02:24 AM   #1
Banana_Cute
Banana_Cute's Avatar
Banana_Cute is an unknown quantity at this point
HKS actuator WITH manual boost controller?
Well I've searched and found not much of an answer except this hilarious thread>>
#/f/showthread.php?t=564019
I've also read quite a few pages on the GT2871R turbo thread but there's 100+ f**king pages. I just need a quick answer if you have personal experience with this or a friend.
Pretty much my set up as of now
Redtop SR
GT2871R with HKS actuator
SARD 550cc Injectors
SARD Fuel Pressure Reg
Aeromotive 340 Fuel Pump
HKS Front Mount and piping and SSQV black edition
Z32 MAF
Apexi Power FC Tuned ECU
boosting at 14psi
Just wondering if I can add on a MBC to increase boost at maybe 17/19psi sometimes for fun or will it be useless?
I understand I can adjust the rod but it seems like if adjusted all the way everyone reached a peak of 14psi.. from what I've read..
Simplicity is the key to brilliance
Banana_Cute is offline   Reply With Quote
Old 08-27-2014, 02:17 PM   #2
Banana_Cute
Bump. No one has done it??
Old 08-27-2014, 02:28 PM   #3
cotbu
cotbu's Avatar
Yes set the internal wastegate to the minimum boost you intend to run. Use the mbc to raise the boost to whatever, can't really say if you'll be able to hit 17 or 19 with the mbc because certain types only bleed off a few psi, other types (ball and spring) will work better. Ebc's are far better than all mbc's. Mho.
Sent from my Highly Tuned Galaxy S3.4!!!
Old 08-27-2014, 02:33 PM   #4
Dboyizmlg
Dboyizmlg's Avatar
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
[QUOTE=cotbu;5710461]Yes set the internal wastegate to the minimum boost you intend to run. Use the mbc to raise the boost to whatever, can't really say if you'll be able to hit 17 or 19 with the mbc because certain types only bleed off a few psi, other types (ball and spring) will work better. Ebc's are far better than all mbc's. Mho.
Exactly what he said^
Dboyizmlg is offline   Reply With Quote
