Closed Thread
Old 11-30-2006, 11:18 PM   #1
coorslightyet
coorslightyet's Avatar
coorslightyet is a well-known jackass
My First 240sx...?
I just bought a 1990 240sx my first one and its hella under powerd. what can help? it has 198,000miles on it.
coorslightyet is offline
Old 11-30-2006, 11:23 PM   #2
Irukandji
Irukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfectionIrukandji is close to perfection
Send a message via AIM to Irukandji
are you serious?
Irukandji is offline
Old 11-30-2006, 11:36 PM   #3
Helghast
Helghast's Avatar
Helghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfectionHelghast is close to perfection
Send a message via AIM to Helghast
Helghast is offline
Old 11-30-2006, 11:42 PM   #4
s13silvia123
s13silvia123's Avatar
lol buy some shoe laces for it maybe a cookie
s13silvia123 is offline
Old 11-30-2006, 11:55 PM   #5
blackflag_Rms13
blackflag_Rms13's Avatar
blackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really niceblackflag_Rms13 is just really nice
wow ~
blackflag_Rms13 is offline
Old 11-30-2006, 11:56 PM   #6
coorslightyet
ya'll are haters, no help
Old 12-01-2006, 12:08 AM   #7
deadpirate
deadpirate's Avatar
deadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfectiondeadpirate is close to perfection
Send a message via AIM to deadpirate Send a message via Yahoo to deadpirate
if u want quick power...with not to much money...get an exhaust, new intake, upgrade the spark plugs and wires, new pullys, new distributor cap, ground kit would help, new headers...i recommend megan racing
dont listen to these guys, they love raggin on noobs
On Track Motorsport Supply-saftey stuff call TOM @ (805)484-3435
deadpirate is offline
Old 12-01-2006, 12:13 AM   #8
OptionZero
OptionZero's Avatar
OptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfection
Send a message via AIM to OptionZero
yeah, get all those bolt-ons for an extra 10 fuckin horsepower. That's gonna help.
What you really need is this guy:
I hope you find that power, maybe you'll kill yourself sooner.
OptionZero is offline
Old 12-01-2006, 12:15 AM   #9
lexusisforlovers
lexusisforlovers is on a distinguished road
Send a message via AIM to lexusisforlovers
hahahahahahahaha^^
LS1 swap
lexusisforlovers is offline
Old 12-01-2006, 12:35 AM   #10
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Ughhh... if you got the car to be fast, and you're poor. GOOD LUCK.
FaLKoN240 is offline
Old 12-01-2006, 12:51 AM   #11
A Spec Products
A Spec Products's Avatar
A Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfection
Send a message via AIM to A Spec Products
Haha you guys are mean.
Focus on cleaning it up first, and fixing the necessities.
Then do the car in a logical order, power is the last of your worries at this point.
And if you need more help, start with suspension then work from there.
A SPEC PRODUCTS CORP
AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more!
626.618.1100 x 103 / aim: aspectuan
Advertiser's Specials! Read / Give Feedback! Please Rate Us!
A Spec Products is offline
Old 12-01-2006, 01:20 AM   #12
juice.def
juice.def's Avatar
juice.def is on a distinguished road
a good list of things i found when i first bought mine more maintinace then performance. good luck have fun make babies.
Tighten and remove slack from accelerator cable.
Use 93 octane and advance timing 3 degrees.
K&N drop in Filter.
300zx Fuel Filter.
Check Tire Pressure.
Remove intake silencer.
Clean all grounds.
Synthetic Oil. Redline MT-90 in Trans.
Reset ECU.
Remove all Sound Deadening material.
Use Distilled Water and one bottle of Water Wetter for coolant.
Clean Throttle Body, PCV valve and etc... with Intake Cleaner not Carb. Cleaner.
Seafoam the Vacumn lines.
BG 44k in the Gas Tank.
Get a Full Tune Up with good Plugs, Wires, Cap and Rotor.
-brake fluid check and maybe bleed and refill check pads as well.
juice.def is offline
Old 12-01-2006, 02:05 AM   #13
Kaizen.
Kaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymoreKaizen. is not welcome here anymore
Or just get nitrous and call it a day.
Because thats how long its going to last
Kaizen. is offline
Old 12-01-2006, 02:21 AM   #14
s13silvia03
s13silvia03's Avatar
Location: PA.....I always thought that dogs...umm...layed eggs, and I learned something today
s13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud of
Send a message via AIM to s13silvia03
240's are slow stock, just fix whats wrong with the car, your probably only making like 90hp, and then worry about adding power. Also, I doubt anyone is "hating", if you purchased a stock 240sx because you heard they were fast, someone obviously lied to you.
s13silvia03 is offline
Old 12-01-2006, 02:29 AM   #15
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
this kind of question should be an instant lock thread.
but im gonna help, get nitrous. the cheapest way to make easy horsepower. Just blow up the engine and find a lower mileage one or go turbo.
drifter808 is offline
Old 12-01-2006, 03:14 AM   #16
kY.gordon
Banned from the Marketplace
kY.gordon's Avatar
kY.gordon can only hope to improve
if you want power, your not going to find it on that engine.
kY.gordon is offline
Old 12-01-2006, 09:06 AM   #17
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
good job making 2 threads about this.
this thing has all the useful information its gunna get.
/thread
EJ253 is offline
Old 12-01-2006, 09:20 AM   #18
S14DB
AFC #1
S14DB's Avatar
/thread
Thanks I thought I just read this...
S14DB is offline
Closed Thread
