Adaptronic Plug-In Select ECU's
Looking for an extremely easy to tune ECU with advanced functions you thought were only available on the most expensive models? The Adaptronic Plug-In Select Series features 100% drop in ECU's for a variety of Nissan applications including: S13 / S14 / S15 SR20 Engines & R32 / R33 / R34 RB Engines All Adaptronic Plug-In Select ECU's include a base map to get the car running, so all you have to do is plug it in! The Adaptronic Plug-In Select ECU's all include an internal 4 BAR MAP sensor, so you can simply run a hose from the barb on the ECU into the engine bay. You may retain the air flow meter if you wish, but MAP sensing is required for most forced-induction applications. Although these ECU's are plug & play, you still have the freedom to configure and tune the ECU as you wish, using the user-friendly WARI tuning software. Pinout tables are provided for all Plug-In Select ECU's, so you know exactly what each input and output is connected to on the engine. General Features:
Please Contact Us if you have any questions regarding availability or functionality of any of the Adaptronic models.
your ad says cheaper than expensive units ,
fyi Apexi Power FC for SR20DET D-Jetro ** PRICE INCLUDES COMMADER! ** Item# powerfcdjetSR Regular price: $1,489.95 Our price: $1,395.00 APEXi Power FC & Tuning Software : SR20DET PRICE INCLUDES NEW COLORED O-LED COMMADER! * MSRP: $1,250.00 Sale price: $1,049.00 AEM EMS Series 2 - S13 SR20DET Price: $1,298.99 SKU: 30-6601 Brand: AEM just a fyi thats all |
Thanks for the FYI. Just to clarify a few differences between the Adaptronic and the others mentioned.
First off the Adaptronic features the ability to use Volumetric Efficiency based tuning versus limited MAF or rigid Speed Density systems. This method makes the tuning process much easier, more linear, and adaptable to changing modifications and running conditions. The Adaptronic does not require a peripheral control unit such as a Datalogit ($300) to simply input a wideband O2 signal, datalog in an easy to use format, or enable other commonly used inputs. The Adaptronic features Adaptive Closed Loop Tuning which when paired with an wideband O2 can 'self tune' during all running conditions including idle, transient throttle (throttle response), as well as under load in boost. This feature is not found in the other ECU's and is what I originally referred to as a function only found on higher priced units (Haltech, Motec, etc.) If you are interested in using alternative fuels such as E85, the Adaptronic can continue to retain adaptive closed loop tuning by simply adding a 'flex sensor'. This fuel sensor measures that actual ethanol mixture in real-time and transmits feedback to the ECU to ensure proper delivery. There are many more included features such as:
Plus for a limited time we are offering a $100 Tax Season Special for Zilvia.net members! This special tax season pricing is only available on Nissan Plug-In Select ECU's. During check out enter the coupon code Zilvia100 If you are interested or have questions about the Adaptronic ECU line or their functions feel free to contact us for more info! P.S. Check out the Sennheiser/Ric Shaw Racing FD3S powered by Adaptronic in this weekend's Bathurst 12 Hour Endurance Race!
