S15 headlight low beam connectors / plugs for S14.5 conversion
Does anyone know what the part number is for the connector in the red circle?
It's for the low beam: I already have the following plugs / connectors: - B4343-79901 -> Parking lights and turn signals - HB3 9005 universal plugs or original Nissan B4342-0UFB0 -> High beam So I'm just missing the one for the low beam. ![]() I found this site, but if I let Google translate I still don't know which I need.... http://www.hiromu-web.com/diy/20041211.html A guy from Japan gave me this list: B4342-0UFB0 B4343-79901 B4342-79906 24028-AG007 So I guess it must be one of the last two options, but I can't find it on the internerd. ![]() |
Do you have more connecters than plugs? That's the issue for me as well except it's for my blinkers. If you want, I'll take a pic of my headlight connecting and post it here.
No, everything is hooked up and works. I'm just not satisfied with how I connect my low beam. I did it without the original plug so I want to buy that one as well.
Do you need some help with hooking up yours? Just take the positive wire from your blinker, the positive wire from you parking light and use a negative wire from either of them. I connected those three wires to the plug with part no. B4343-79901. And everything's working fine. |
