E- brake. No.
How do I put this back in, wouldn't go back down and when It did this moved freely in and out. Any suggestions appreciated. Every time I searched all I found was idiots asking why their wheels don't lock x.x Sent from my iPhone using Tapatalk |
![]() Join Date: May 2012
I had this problem a while back and it is a bitch to get back in. I had the most luck by unbolting the ebrake and then trying to put in from the back. I resorted to bending the metal tab with a screwdriver and then bending it back once I had it all put back together. Hard to explain but just keep messing with it and youll get it.
Well the previous owner has the 10mm so tight I can't loosen it, so will it be a problem if I dismount it, to then re mount it, or could I probably fix both by dismounting it?
