#61 | |
I highly recommend you read the thread over again, as if the temp probe is indeed reading what is coming out of the head, you can place the probe in the outlet. OR, you can do below (drill and tap the stock housing) There is more than one way to skin a cat ![]() |
#62 | |
![]() Join Date: Jul 2005
couldnt resist. ![]() I like the water temp reading coming out of the engine. I want to know if my new timing settings are heating up the water, as a tuning technique, one can see that a 30 second 5th gear pull with 12* of timing vs 6* of timing there is a difference of 20*C final temperature rise after 30 seconds of boosting in 5th. |
#63 | |
wat. |
#64 |
My Defi sensor is in the upper coolant neck, which is also the coolant out to the radiator from the head. I have a slightly different engine configuration being that I have a VVL setup. My temp readout on the Haltech(which is in the "factory" position) reads 1-2degrees different from the Defi sensor. The upper outlet gives you a better indication of what your engine temps are. Why would you want to know how cool the coolant is going back into the motor, other than to see how efficient your radiator/fan setup is?
My SR20VET |
#65 | |
![]() Join Date: Apr 2006
http://www.turbobygarrett.com/turbob...low_off_valves downstream of the cooler = near the TB |
#66 |
Why Mike, must you add fuel to the fire?
He read it in a book, so it must be true. I'm sure he'll come in here with some math equations, that have absolutely nothing to do with the topic at hand or anything in general, proving you are wrong if you calculate them. But it is funny...
My SR20VET |
#67 | ||
#68 | |
He's a character that's for sure.
My SR20VET |
#69 |
![]() Join Date: Feb 2008
![]() ![]() Feedback Score: 16 reviews
Update, threw in the Nismo thermo and a new OEM waterpump. I put in around 30% coolant and 70% distilled water with a bottle of Water Wetter. This car in normal driving barely sees over 85C, its usually between 75C-85C. When I throw on the A/C the car gets around 90-95C.
Is that around the normal temps for when the air conditioning is on? Was wondering if that was too high. My girl even surprised me with a gift. (For all you gamers out there)
#70 |
![]() Join Date: Mar 2009
If I don't want to remove my stock sensors from the housing, isn't the lower hose as close as I can get to it? Installed my yashio factory water pump pulley, 110 outside on the way home from work about a 40 minute drive, temps stayed around 165-170 in the lower hose cruising at 60mph.
#71 | |
Short of the answer: NO, the lower hose is the incorrect placement for the sensor (which has been said several times over and I posted a coolant path diagram from the FSM...................) |
#73 | |
![]() However, its your car and you can do as you please........... |
#74 |
![]() Join Date: Apr 2013
I live in New York
- Chuki frontend ( Cut ) - Isis Radiator w/ dual e-fans - Samco hoses - Nismo thermostat - Stance oversized water pump pulley - Radiator cooling panel Driving from home to work and around I average about 158-170. I do plan on running a breather tank in the near future so that it constantly bleeds the radiator, deffitnitly a good investment. |
#76 | |
>Upper waterneck.<
Zilvians have now gone from 'Cannot search for a topic' to 'Cannot draw conclusion from thread' |
#77 | |
#79 |
![]() Join Date: Mar 2013
interesting thread. i am switching back to clutch fan and shroud myself, with gktech's fan blades. i was impressed by that article , what it said about ducting. i guess it's time to get the measuring tape out and do some work!
My Build |
#80 | |
![]() The biggest difference I see as far as temps are concerned (be it in boost or regular driving) is DUCT WORK! Not a Nismo thermo, upper panel, etc. Lower engine panel Ducting intercooler Ducting the sides between the opening on the bumper and the condenser/radiator (big gaping gaps on both sides) etc. Not many people here are willing to take a few hours and some thinking to do it however........even though its the cheapest most effective mod for aiding in cooling (the panel I made cost me about $30. The aftermarket upper cooling panel is on average 50-100........and it does nothing without the other duct work) |
#81 |
dude, quit being a fucking moron. stop for a second and think about the way the system works.
I've attached some retard-spec photos for you. You really shouldnt have any questions after this. Last edited by ixfxi; 12-26-2014 at 05:26 PM.. |
