Old 03-28-2013, 07:08 PM   #1
fwd-240
fwd-240 is an unknown quantity at this point
An issue i bet you can't help me fix lol
I have a s13 sr vert that ran just fine and the left fender harness was rubbed and had some wires exposed and killed the battery. So now everytime i hook the battery up the boost controller stays beeping and when i hook the keys up the the ignition and turn the windshield wipers fire up and are not able to turn off and the car does not start while the starter spins freely
I have taped up all the exposed wires and still NOTHING HAS CHANGED.
PLEASE ZILVIA HELP
fwd-240 is offline   Reply With Quote
Old 03-28-2013, 07:36 PM   #2
roboticnissan
roboticnissan's Avatar
Fried ecu? What kind of bc do you have that beeps?
roboticnissan is offline   Reply With Quote
Old 03-28-2013, 07:44 PM   #3
fwd-240
How can i know forsure if the ecu is fried
Old 03-28-2013, 07:47 PM   #4
wawazat8402
wawazat8402 is an unknown quantity at this point
Send a message via AIM to wawazat8402
Did you tape up the wires individually or just rewrap the entire harness?
wawazat8402 is offline   Reply With Quote
Old 03-28-2013, 07:49 PM   #5
Phoenix4987
Phoenix4987 is an unknown quantity at this point
wiring gremlin. check that shit and resplice if you have to
Phoenix4987 is offline   Reply With Quote
Old 03-28-2013, 07:51 PM   #6
fwd-240
I taped up everything individually
Old 03-28-2013, 07:57 PM   #7
Petitt
Petitt's Avatar
Petitt is an unknown quantity at this point
Sounds like cancer.
Petitt is offline   Reply With Quote
Old 03-29-2013, 12:05 AM   #8
fwd-240
so far my most probable cause may be too many ignition taps and it made my wiper wires melt and starter solenoid pop..
this will be checked tomorrow
Old 03-29-2013, 12:10 AM   #9
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
check fuses, check shit.
OrangeVirus1 is offline   Reply With Quote
Old 03-29-2013, 12:11 AM   #10
fwd-240
i did , i promise
Old 03-30-2013, 08:34 AM   #11
Chaluska
Chaluska is an unknown quantity at this point
time to get a new car
Chaluska is offline   Reply With Quote
Old 03-30-2013, 08:39 AM   #12
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
What you have to do is now pull harness
Go thru each wire individually and solder (not tape) and then shrink warp them. Then check all fuses and relays.
That's the only option beyond replacing them all (if your lazy to do the above)
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
