Old 10-24-2012, 07:07 PM   #1
Slims
Slims's Avatar
Slims is an unknown quantity at this point
Chevy Gen V Small-block (End of the LS series)
LINK IS AT THE BOTTOM.
So with Chevy's end of research on the LS series, I thought it would post this up. I'm still reading it my self, but thought it would be a good discussion. whats some of your' views on the future of the LS engine that seems to be dominating a big part of the car industry right now. Changes in price, aftermarket production, possible new platform swaps for some people soon?
just some specs of the new engine found in here.
Engine type: 90-degree V-8 with overhead valves; continuous VVT
Displacement: 6.2L (376 cubic inches)
Bore x Stroke (in / mm): 4.06 x 3.62 / 103.25 x 92
Cylinder block: cast aluminum with nodular main caps
Main bearing fasteners: six, including two cross-bolts per cap
Crankshaft: forged steel
Connecting rods: powder metal, 6.125 inches in length
Pistons: eutectic aluminum alloy
Compression ratio: 11.5:1
Cylinder heads: 319-T7 cast aluminum with 59.02cc combustion chambers
Valve angles (degrees): 12.5 intake, 12 exhaust
Intake valves: 2.13 inches (54mm) hollow
Exhaust valves: 1.59 inches (40.4mm) hollow sodium
Camshaft: Hydraulic-type with tri-lobe for fuel-pump drive
Camshaft lift: 0.551-inch (14mm) intake / 0.524-inch (13.3mm) exhaust
Camshaft duration: 200-degrees intake / 207-degrees exhaust (at 0.050-inch)
Lobe separation angle: 116.5 degrees
Fuel delivery: direct injection
Intake manifold: “runners in a box” design; composite construction
Throttle: 87mm electronically controlled throttle body
Ignition: 58X with individual coil-on-plug and iridium-tip spark plugs
Horsepower / kW: 450 / 335 (estimated)
Torque – lb.-ft. / Nm: 450 / 610 (estimated)
Max. engine speed 6,600 rpm (fuel cutoff)
Breaking News: Chevy Gen V Small-block Reveal - EngineLabs
Slims is offline   Reply With Quote
Old 10-24-2012, 09:13 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Maybe we can get lsx swaps for cheap now! since its an outdatted technology
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 10-25-2012, 10:55 PM   #3
zerodameaon
zerodameaon's Avatar
I like how they are going back to the LT designation. Rednecks will be massively confused in years to come.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 10-25-2012, 11:34 PM   #4
Mofuhcka
Barrys World
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
If this means older gens will be cheaper, Im gonna be excited
Mofuhcka is offline   Reply With Quote
Old 11-02-2012, 12:24 PM   #5
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
I would say if these engines get cheaper i would look into this v8 swap, i mean i would get same gas mileage as my tired KA24E with tons more power. I'm in for updates.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 11-06-2012, 02:36 PM   #6
SCRmotorsports
SCRmotorsports's Avatar
SCRmotorsports is an unknown quantity at this point
i found out the cheapest way for me too go where i live due too hardly any wrecked vettes,gtos,camaro's, but a gmc envoy has a aluminum 5.3 there about $900, where as a truck iron block 5.3 is $600 but still thats cheap! in my opinion the only way too go if your doing a swap and have a little cash too work with. you cant beat nearly 30mpg and 400hp my ka gets maybe 22 on the highway and 17 in town and its slowwww.
SCRmotorsports is offline   Reply With Quote
Old 11-08-2012, 09:32 PM   #7
Corbic
Corbic's Avatar
A 5.3L is not exactly cheaper.
The Oil Pan, Intake, exhaust and accessories are utterly worthless in 99.9% of applications. These items will add up to $1000 easily.
The 5.3L makes a great core, and will take boost like no tomorrow, but it's not the smoking gun for a cheap swap. You'll also still need to source a T56 or TKO, both options are also not cheap.
Old 11-08-2012, 09:38 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I think it's great. I look forward to the 100 dollar engine days at Harry's Race Pull it Parts, 5.3's are a dime a dozen!
