Closed Thread
Old 01-02-2006, 07:53 PM   #1
drift240_05
drift240_05 is an unknown quantity at this point
KA selling
my name is erek lewis and i have been a 240 guy for a few years now, I built a high compression kamotor and droped it into my 240. some thing have come up and I have to sell it now, fiance is having a baby, and cannot keep the car, the engine has less then 10,000 miles on it and the suspension has a few thousand more, the exhaust system was done at the same time as the suspension.
here is a list of the modifications I have done...
Engine/transmission:
- DOHC swap
- Custom Arias 10:6 compression pistons
- Bored 0.020 over, to a 2.5 liter
- Milled block and head
- Fully new internals, bottom end and top end
- Race ported & polished head
- Port matched intake manifold
- 5-angle valve job
- Swirl polished valves
- Jim Wolf valve springs and retainers
- Full new engine gasket set
- New polyurethane motor mounts
- 255 lph Walbro fuel pump
- ACT 2100 pressure plate, six puck un-sprung clutch disc, and throwout bearing
- Machined flywheel
- Stainless steel OBX 4-2-1 header
- Full 2.5’’ exhaust, Dynomax high flow cat, and magnaflow muffler
- MSD Blaster 2 coil
- NGK silicone plug wires
- NGK iridium plugs
- Air filter box eliminator kit
- Optima red top battery
- Powder coated valve cover
Interior:
- Sparco Evo seats, with Greddy 4 pt. harnesses
- Auto meter air/fuel, and oil pressure gauges
- Custom made seat mounting brackets
- Apex! super air fuel converter (safcII)
- Gutted interior
- Grant steering wheel
Exterior:
- KYB GR2 struts, Eibach sport line springs
- Suspension Techniques sway bars and end links
- SPL front tension rods (caster adjustment)
- Brembo slotted rotors all around, and Hawk Ferro carbon pads
- 600° racing brake fluid
- Tenzo Racing Formula 10 wheels, with Bridgestone Potenza RE011 (215/45-17) tires
Good stuff - this car HAULS and sounds great. Awesome drift car or autocross car, daily driver, but never entered in events. Only 10,000 miles since work was completed.
Bad stuff - the engine has a slight oil leak at the oil pan, but I have not had time to fix it as a full time student and part time worker. The clutch throwout bearing/transmission (we don't know which one)makes a noise occasionally, but we can't determine why - the bearing/trans were installed along with the ACT clutch by a technician and drift driver with over 20 years of tuning and repairing imports. There is a slight bit of rust and body filler on the right rear quarter, along with the normal dings and scratches and paint issues of a 15 year old car. I also have a 1991-1994 front fascia and fenders if you're interested, I will throw it in for $150 extra.
I have over $6,700.00 in the engine/transmission alone, $1,300.00 in seats, and another $2,000.00 in wheels/tires/suspension. my loss is your gain. The next step for the car was custom paint and body work, but the baby comes first. Over $11,000.00 invested, sacrificing at $5,500.00.
any questions or for pictures e-mail me at [email protected], thank you
drift240_05 is offline
Old 05-21-2006, 02:14 AM   #2
sime3479
sime3479 is an unknown quantity at this point
BUMP!
I have a question though; What is a "- 5-angle valve job"?
sime3479 is offline
Old 05-21-2006, 08:19 AM   #3
Phlip
Phlip's Avatar
#/f/showthread.php?t=109059
... try again and play by the rules this time
And I write too!
Phlip is offline
Closed Thread
