![]() Join Date: Dec 2010
Sr20 PS pulley
I have an s14 sr motor set going in on sunday. The ps pulley is damaged and I can't seem to find one to replace it. Was considering using the s13 sr pulley in it's place and running w the extra rib. Has anyone else done this? Had any problems with the belt skipping around? Do the grooves line up correctly?
Thanks for the help, ive searched extensively and can't find a definitive answer |
![]() Join Date: Mar 2011
why not just get a cheap pulley set for like $60? Touge Factory or Circuit Sports....etc
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
Just use your KA pump assembly and SR bracket... No need to change anything it bolts right on.
My SR20VET |
Yeah I know. But s13 and s14 are different and the only s14 pulleys I can find say they are underdrive. So Unless they are misadvertized they would not be the stock size and I would need dif belts. But I don't know which belts I would need...so I'm kinda in a fucked up spot
All the s13 pulley kits will work with s14 sr's, however the you have an extra rib on the pulley.
Touge Factory is the set I have they are really nice.
You're using s13 pulleys on your s14 w no problems? Nice. Ill order them first thing tomorrow. Doing the swap tomorrow morning (starting tomorrow morning anyway)
thanks for the input |
All you have to do is take a piece of string, yarn, whatever the hell you have laying around and take a measurement. Once you have the measurement, you can pretty much determine what size belt you have.
My SR20VET |
No I have them on my s13 but check out out touge factory's website or call them that is what they will tell you. There is no difference between the motorset pulleys besides that extra rib which will not effect anything.
