Just been on this build for a while
and this is what I got. 8.5=1 cp piston, eagle rods, acl main, rods , thrust Bearings honed and bored block .20 over= 86.50 Not 86 no more lol, gt3071r turbo top mount manifold 38 mm. wastegatearp bolts 87mm apex metal head Gasket, specs clutch stage 3 6 puck Everything Is stock except front mount and soon Walbro255Lph high volume fuel pump with fpr and 750cc injectors. Now the question is how much power can I make? With stock tune and then aem ems. I also have a stock det head not ve sorry. guys lol |
![]() Join Date: May 2011
Built block, stand alone, but stock head?
With that big turbo get cams other wise that turbo just won't get enough air to breath. Cams will bring it to life.
TheHead is stock for now will up grade
To Bc cams maybe 264 or 272 with Spring, retainers, solid lifters and a valve job In The future this is my only car and needs transportation quick so trying to build a FastDaily driver |
![]() Join Date: Oct 2006
I'm betting somewhere upwards of 350 whp. I have a GT3071R, Crower rods, CP pistons (9:1), built head and 1000cc injectors and cranked out 435 whp on 20 psi.
This build was done a long time ago and with
t3/,t3 Turbo but the shop who put it together didn't torque nothing to correct specs so piston hit top.of the valve rod hit side of the wall and Put two holes in it but now I got s13 SR stock motor with s14 Turbo 550cc injectors z32 maf and a romtune at 16 psi hopefully next month going to dyno and make 325hp |
