![]() Join Date: Jun 2003
Trader Rating: (129)
rhd front clip s13 kouki 180sx
up for sale is a bare clip. it was a kouki 180sx. it is zomgjdmtyte.
no engine included. this is useful if you are doing a rhd conversion. i repeat, NO ENGINE INCLUDED. Pickup only, NO SHIPPING. I would prefer someone who wants the whole thing, I don't really wanna part it out bit by bit, but we'll see..... $550 picked up in solana beach there is a ton of stuff still on here FIRST OFF, I do not have: -ANY body panels. no doors, no hoods, no fenders, no bumpers, no lights, no turn signals, NO BODY PANELS -Steering rack. already gone. -center console -radio trim -digital heater control panel -engine subframe (same as usdm anyways) I DO HAVE: -RHD DASH (There is a big square cut out above the glovebox, previous owner had a flip out tv screen here). all 3 defrost vents are uncracked and it has the sunload sensor for digital heater control unit -rhd steering column -rhd under-dash panel -rhd hood release cable -kouki 180sx instrument cluster. i plugged it in and powered it up, all bulbs appear to be functioning, photos updated, only 65k (km, not miles) -steering column covers, wiper stalk and turn signal stalk. kouki 180 wiper stalk is different than usdm, this car came with airbag, so that is available too -ign cylinder with generic key -black carpet CARPET IS SOLD -rhd fuse boxes and tons of wiring. -rhd brake master cylinder and lines, master is 15/16, same as '89 non-abs z32 300zx -rhd brake booster (maybe same as usdm? i dunno) -rhd clutch master cylinder and line (slave not included) -rhd firewall. i can cut it behind the shock towers or leave the full front end intact, your choice -complete a/c setup, still intact. sr20det compressor, receiver/drier, condensor, a/c fan, all lines. i do not have the digital heater control unit, but it looks like some of the wiring and components for the digital unit are still under the dash. it is a r-134 system and as far as i can tell might still be charged? i don't see anywhere that is kinked/cut/broken/pinched/etc -180sx front brakes (calipers, rotors, pads, spindles with ABS sensors, LCA, stock tension rods) 180sx front brakes are larger than usdm s13 front brakes -sway bar (front) i think its same as usdm? -coolant reservoir. one of the cleanest i've ever seen. -rhd windshield wiper motor and linkages -car originally had ABS so it still has wiring and plugs for it, but the ABS module has been removed. -brake, clutch, and gas pedal with throttle cable -awesome jdm rocks and dirt. I'm probably forgetting shit, i'll update as necessary. Again, i'm willing to part shit out, but i'd prefer someone who wants the whole thing. ok now pix..... ![]() ![]() ![]() ![]() carpet after quick vacuum ![]() ![]() ![]() ![]() a/c compressor still attached ![]() kouki cluster ![]() ![]() ![]() Last edited by brndck; 09-20-2012 at 02:37 PM.. |
![]() Join Date: Sep 2007
omg how much for that brown JDM rock sitting on the carpet?!?!
no jk, but if you still have the A/C setup within the next month or so once my right hand drive is in I'll pick it up if its at a decent price...what were you looking to get for it? |
STILL HAVE THIS SHIT!!!! a little bit flexible on price.
still got lots of stuff. want it all gone. just taking up space.
i cut off most of the sheetmetal just the about 6" in front and behind the firewall for ease of transport. |
![]() Join Date: Sep 2012
can you take more closer pics of the dash where radio is supposed to be please... I"m trying to put mine back together and I'm trying to see wiring stuff for it
all the wiring has been removed from the "car". if you have photos of exactly what wiring you need i can look and see if i have it.
a/c setup has been sold.
tons of stuff still available. willing to part shit out. |
hey there is a blank panel where the wipers bolt too its a black strip between the windshield and the enginebay do you have all the little black square clips for that? if so do you want to sell those.. also do you have the do you have the windshield washer resevor, rubber lines and motor? also looking for some interior bolts if you have some the panel under the steering wheel I beleive they call it the kick panel?
still got tons of parts. pm me for details.
#20 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
If you decide to part out PM me if you have the DCC "Aspirtor Tube" Only
My Build: The "Coupe De Ville" 1JZ Build!! |
#21 |
still have tons of stuff.
want the firewall and dash gone asap. make offer, most likely i'll accept it. |
#24 |
ok most of this stuff is gone, but i do still have the dash and firewall and i want em gone ASAP.
(like bring me a #2 animal style from in n out and you can have em) |
#28 |
bump. need the firewall gone. $20 picked up???
#29 |
still have this. need it gone. taking up too much space.
